2002 stator upgrade? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-02-2014, 10:45 AM Thread Starter
I'm searching used V strom 1000's and found a low mileage 2002. I under stand that in 03 Suzuki up graded the stators to 400 watts. Can you replace the 02 ststot with a newer oem stator to upgrade it to the 400 watts??
Thanks,
Mike
HOOVEY is offline
post #2 of 4 Old 04-02-2014, 10:53 AM
The rotor changed too.
post #3 of 4 Old 04-02-2014, 03:02 PM
bwringer's Avatar
The data is murky at best, but it may be that the 2002-03 Vees don't melt their stators or suffer from wandering rotor magnets quite as often as the later models.
But honestly, what difference would an occasional theoretical 50 watts make in your life?
One worthwhile upgrade would be the regulator/rectifier. A MOSFET or series R/R will give you much steadier voltage levels at lower RPM than the stock unit and wastes less energy.
bwringer is offline
post #4 of 4 Old 04-02-2014, 03:13 PM
2002 - 350W
2003 and later - 400W
MOSFET R/Rs due keep voltages steadier in my experience but they don't provide any more power or waste less energy AFAIK.
