Pelicans on factory racks? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 01-08-2014, 03:01 PM Thread Starter
Has anyone successfully mounted pelican cases on pre k12 Suzuki luggage racks? I'm looking to buy a 2009 650 with original Suzuki racks and hard luggage. The luggage looks like crap but the racks seem OK. I have some pelicans I could put on. I know I could just cut and bolt, but I'd like to know if I could some how use the quick release system??
revrat is offline
post #2 of 14 Old 01-09-2014, 02:02 PM
kbyte255's Avatar
I can't help since I did away with the "quick-release" hardware. I bolted my Pelicans directly to the factory rack. I used 1/4" stainless bolts. A couple pieces of 1" aluminum flatstock inside the cases help spread the load.
I like the set-up and don't regret not using a quick release option.
kbyte255 is offline
post #3 of 14 Old 01-09-2014, 02:11 PM
Hard miles's Avatar
photos please
Would you have photographs of the setup. I am considering the same setup.
Brian
Hard miles is offline
post #4 of 14 Old 01-09-2014, 11:03 PM
I did the same as Kbyte255 with the Sea Horse bags. Keeno, man.
They are only as wide as the handle bars so it ain't lane split problem.
post #5 of 14 Old 01-10-2014, 12:12 AM Thread Starter
Pictures??
revrat is offline
post #6 of 14 Old 01-10-2014, 03:00 AM
I mounted my Pelicans to the factory rack using the quick release mounting kit from Twisted Throttle.
Had to move a few of the mounting studs but wasn't to big of a deal and I'm very happy with the setup.
Peter
strompeter is offline
post #7 of 14 Old 01-10-2014, 05:34 AM
Even the factory cases are not great, what you can fit in Pelican cases? Thay are so narrow...
Rick123 is offline
post #8 of 14 Old 01-10-2014, 10:32 AM
Revrat, sorry, no pics. I just used the factory holes in the frame for the mounting hardware and used new 1/4 20 bolts from the store. There are big washers called fender washers that spread out the stress. I also mounted the bags so they are not at an angle. I like a flat perch for my coffee cup.
post #9 of 14 Old 01-10-2014, 11:13 AM Thread Starter
There are many different pelican cases. I don't remember what number mine are but I can fit everything I need for multi day camping in my two without a top box. I just like taking them off since they are side load and it's easier to get everything in and out if they are on the picnic table. They hold more then the Suzuki hard (hard is an exaggeration) bags.
revrat is offline
post #10 of 14 Old 01-10-2014, 11:19 AM Thread Starter
Peter
This one?
TraX Adapter kit for SW-MOTECH Quick-Lock EVO sidecarriers - Luggage & Racks - Shop by Product - TwistedThrottle.com
revrat is offline
