Symtec grip heater switch? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-07-2014, 04:14 PM Thread Starter
I installed a Symtec grip heater kit (16025) on my 07 Wee, hooking into the free switched circuit behind the radiator. It worked perfectly when first installed (for about a month). The heaters no longer work, there is current to the rocker switch, and there is continuity on both high and low circuits to the grips, so I assume the switch is at fault. I mounted the switch on the horizontal surface of the meter housing panel, so it gets wet. Has anyone had a symtec rocker switch fail due to water exposure, and found a solution?
sunnyboy is offline
post #2 of 5 Old 01-07-2014, 05:06 PM
Chewy's Avatar
I just replaced the rocker switch on my Symtec for about $5.00 plus shipping from amotostuff. The switch is poorly designed and does not drain water if it's installed in the horizontal position. It lasted about 5 years.
Chewy is offline
post #3 of 5 Old 01-07-2014, 05:27 PM
enumclaw's Avatar
I bought a few much higher quality switches (it wasn't hard) from Digikey a couple years ago. PM me your address and I'll send you one, gratis, if you'd like. The replacements are a direct fit, connection points and all, but much more robust.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #4 of 5 Old 01-07-2014, 06:22 PM
MeefZah's Avatar
Yes, I have had 2 fail. In a very weird coincidence, I was in Warren PA both times.
Just replace it with a SPDT toggle switch. No big deal. You'll get about 1-2 years out of a switch when used on a bike due to exposure to weather and such.
MeefZah is offline
post #5 of 5 Old 01-08-2014, 07:38 PM Thread Starter
Thanks Rob. Sounds like the ideal fix. I sent a PM with my address. Please let me know the cost so I can cover it.
sunnyboy is offline
