question about centerstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-05-2014, 06:45 PM Thread Starter
I wanted to find out if you still used the side stand with the centerstand
nickvolvo40 is offline
post #2 of 7 Old 01-05-2014, 07:13 PM
kiwi_outdoors's Avatar
YEs !!!
put bike on side stand
get off bike
put bike on centerstand for maintenance or parking
for my EX250 I could omit the sidestand step, even when parking - not so much on the taller heavier DL650 - which is how I embarrassed myself returning a rental G800GS - the bike and I hit the floor in SloMo
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #3 of 7 Old 01-05-2014, 07:18 PM
Like Kiwi, put it on the side so it don't fall over and then up on the center stand for stability. My bike is an 04 and it leans a lot on the side stand so the center stand makes easier to use.
I have friends who are not veritcally challenged and get off the bike and then deploy the stand.
notacop is online now
post #4 of 7 Old 01-05-2014, 08:00 PM
teevee's Avatar
mine did too, until i installed the bashplate and discovered that the sidestand nut was SUPER loose
'08 DR650, '07 DL1000
teevee is offline
post #5 of 7 Old 01-05-2014, 08:23 PM
Stalky Tracker's Avatar
Yep, especially in dirt, gravel, mud, etc. The side stand works much better there. :mrgreen:
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #6 of 7 Old 01-05-2014, 10:28 PM Thread Starter
So I can use the sidestand when im out then when I park in the garage I can use the centerstand correct
post #7 of 7 Old 01-05-2014, 10:34 PM
Yes you can. Using the centerstand will actually give you a little more room if parking in a tight space.
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
