Seafoam - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 22 Old 12-31-2013, 02:28 PM Thread Starter
Seafoam
After 65,000 trouble-free miles I thought I'd run some Seafoam as a preventative, in case some deposits have built up in the fuel system. After pouring in the appropriate amount for a full tank and running the engine for a few minutes to get the mixture into the system, what have you found best: let it sit for a while (say overnight) and then take a long ride or, take a long ride right after adding the Seafoam? Or does it make no difference?
keetmanaa is offline
post #2 of 22 Old 12-31-2013, 03:10 PM
SeaFoam to the rescue
I had a recalcitrant KLR a couple winters ago. It would run, but stall when you dropped the RPM or tried idling (even when warmed up). The design of the carb jet is an unusual one, a perforated needle with TINY holes along its shaft. Evidently gummed.
I siphoned out all the not-that-old fuel, bought some new, mixed with appropriate amount of the magic juice under discussion, into the tank. Start-up and run an errand or two -- fixed! I was impressed. Usually a Pierre-Bayle-Fan-Club card-carrying member, I am now a believer. A new bottle/can is on my wish list for the next birthday.
I've added some to the Strom, but not having a problem, didn't notice any difference. Your results (like mileage) may vary.
Freezin'_Geezer is offline
post #3 of 22 Old 12-31-2013, 03:16 PM
I prefer a product by BG called 44K, but seafoam works, too.
You need to run the tank out. I plan my treatment around that. I'll wait until I know I'm going out for awhile, then add some. Maybe once or twice a year, depending on mileage.
Those that think it's snake oil, I disagree.
2007 DL 650 with assorted upgrades
Solo is offline
post #4 of 22 Old 12-31-2013, 04:18 PM
XS Bert's Avatar
I don't think it's snake oil, but it sure works great for me. If you read the directions, it can also be used in crank case oil. Just before you are going to change oil,dump about half can in crankcase,let run to temp.(no reving) drain oil and replace. Gets any carbon deposits off valves and rings. Works real well for me,jmho. The reason you add Seafoam every once in a while is so you don't have any problems,cleans the deposits out of fuel system.
XS Bert is offline
post #5 of 22 Old 12-31-2013, 05:04 PM
Ex- moderator
I use it in my Vstrom, my Vincent, my V6 Accord and my wifes Civic..I told my sister to dump 1/2 can into the tank of her Subaru (I assumed the approx. 16 oz can...) ...she bought a U.S gallon, dumped 1/2 of it in the tank and then called me to say "its quite expensive at $65.00/can".... and, "you're right, it works.."
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #6 of 22 Old 12-31-2013, 06:39 PM
Yes in the tank the crankcase, as a mixer with Vodka.
If you think you may nave a deposit like on a cars butterfly they recommend letting a coating sit overnight. They actually make a can with a straw to squirt into the intake track.
richw is offline
post #7 of 22 Old 12-31-2013, 06:40 PM
Green427's Avatar
I am not sure if I ever noticed a difference when using it as a fuel stabilizer in my bikes....then again, I haven't gone more than two months without riding in any season....however, I have used it in engines that have had gummy deposits in the fuel system, and it seems to work well in cleaning up the deposits.
1995 Honda CB750 - sold
2005 Honda Rebel -sold
1990 Honda PC800 -sold
2007 DL650 - sold
2011 DL650A - current
Green427 is offline
post #8 of 22 Old 12-31-2013, 06:55 PM
tiller4me's Avatar
IMHO, I would let it sit for a spell, (overnight) and allow it to soften up any deposits. Then take it for a spin. Somewhere away from traffic, I would run the engine up to red line and allow to coast down a time or three. This would allow the increased vacuum to dislodge any loosened particles.
In my experiences, (mostly with carbureted bikes), the longer Seafoam stays in the system the better it works.
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #9 of 22 Old 12-31-2013, 07:07 PM
I've used the fuel injector cleaner in the car on occasion just because. I haven't seen and dramatic difference. If you use what is referred to as TOP TIER gas...major suppliers...then the additives are in there already and cleaning as you go.
Most problems occur from the vehicle sitting and the new style gas evaporating and leaving unsightly deposits in small places.
Conversely, a lot of folks have tales of the perceived benefits of it's use.
notacop is online now
post #10 of 22 Old 12-31-2013, 07:25 PM
Techron is probably the all around better product out there, but have also used Seafom as well.
RichWee likes this.
Big B is online now
