Need advice on: GPS Mount, Tires, Upper and lower protectors. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 12-29-2013, 09:22 AM Thread Starter
Red5's Avatar
Would like to fit my Magellan RoadMate 1475T 4.7-Inch Portable GPS Navigator onto my VSTROM. I just bought a 12v kit and am installing it today.
Looking for suggestions for a mount.
Tires: I'm thinking 20/90- Guess you don't need to answer this one as it is a changing thing- I'll read up on tires.
The upper and lower body / frame protectors. Where are you guys finding the best deals on these? If I plan on doing some offroad action I guess it makes sense to buy both.
Bark Busters. What works?
Thanks
Red5 is offline
post #2 of 14 Old 12-29-2013, 09:52 AM
Byronw's Avatar
I'm using this low-buck GPS mount, Amazon.com solution. I've used this for four years now, with a $35.00 ebay Garmin 205W. I use a dry erase pen to scribble my route on the windshield, helps me manage the county roads and highways through my day. On my last rest or gas stop I plug in the motel address, and it gets me there. I won't go on a road trip without it.
Byronw is offline
post #3 of 14 Old 12-29-2013, 11:17 AM
raYzerman's Avatar
I'm one of those who likes to pre-plan routes and load them to the GPS, with the option to deviate if I so choose. I prefer the GPS up higher so I don't have to look far away from the road/traffic, so I'm putting mine above the instruments.
raYzerman is offline
post #4 of 14 Old 12-29-2013, 02:42 PM
Stalky Tracker's Avatar
Same here, it's just a slight glance down and back to the road. I have my Garmin 2730 mounted with the Garmin motorcycle mount to the SW-Motech vibration damped mount which puts it under the windshield and above the gauges.
There are other mounts. Adventure Tech makes one that uses RAM type mounting and puts the GPS in about the same place. Touratech makes one too. Any place you can mount a RAM mount you should be able to mount a GPS. And Bags Connection makes one for attaching a GPS to their tank bags.
For crash bars and skid plates; here's a start: https://www.stromtrooper.com/general-...ne-guards.html
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 14 Old 12-30-2013, 01:14 PM
I use my tank bag and have for a few years now with no problems. I have a couple of strips of Velcro on each device and it never goes anywhere even in high winds and truck blast. It's also well dampened from vibration. Since it's bluetooth capable I don't need to look down to see it and when I might want to I just pull over.
DL650k9 Orange
TomDevlin is offline
post #6 of 14 Old 12-30-2013, 08:34 PM
I've mounted my GPS and my radar detector on my bike. Start with a 1/2" bar from Twisted Throttle that mounts to your handle bars. Then using mounts from Ram I mount the GPS on the left side and rd on the right. The GPS is hardwired to the battery and the rd is connects to my tankbag which is also wired to the battery. Works great.
Just like some of the others I layout a route of primarily two lane backroads on the computer and then transfer them down to the GPS.
[SIGPIC][/SIGPIC]NOGEEZER (at least in my own mind!)
'65 Ducati 160 Monza
'67 Yamaha 350
'81 Honda 900C
'97 BMW R1200c
'00 Triumph Sprint ST
'98 Suzuki TL1000R
'02 BMW R1100S
'03 BMW K1200GT
'13 Suzuki DL650 V-Strom
NOGEEZER is offline
post #7 of 14 Old 12-30-2013, 09:39 PM
Downs's Avatar
GPS-RAM mount either on the handle bars or above the dash using some of the available options for putting it there.
Tires-I always suggest Shinko 705s. They are long lasting and provide good grip on dirt and on the street.
Check out Home Page for your skidplate and crashbar needs.
Downs is offline
post #8 of 14 Old 12-30-2013, 09:47 PM
srpkcop's Avatar
I went with the Richland Rick above dash mount. It is shipped with a RAM inch ball. Good quality.
srpkcop is offline
post #9 of 14 Old 12-30-2013, 09:48 PM
srpkcop's Avatar
I meant one inch RAM ball.
srpkcop is offline
post #10 of 14 Old 12-30-2013, 10:57 PM
VSrider's Avatar
I use a RAM mount to the left handlebar. Very easy to reach.
VSrider is offline
