Givi question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 12-17-2013, 03:41 PM Thread Starter
Givi question
So on my new to me DL1000 I have Givi hard cases. Here is the question. What do you do for the passenger to lean back against?
tdewitt is offline
post #2 of 10 Old 12-17-2013, 04:14 PM
Banned
the passenger should be wearing a motorcycle jacket with built in back protection = padding
problem solved
Rashnak is offline
post #3 of 10 Old 12-17-2013, 04:36 PM
You get a top case or box and add the back pad kit, or there are some backrest options out there as well.
post #4 of 10 Old 12-17-2013, 05:23 PM
Kamzilla's Avatar
I have a Givi topcase with a back pad. My wife loves it.
Kam
09 DL650, 10 Elite
Kamzilla is offline
post #5 of 10 Old 12-17-2013, 06:41 PM
EFS
What are some of the other backrest options with a top case besides the pad? Thanks in advance!
EFS is offline
post #6 of 10 Old 12-17-2013, 08:40 PM
I believe there is one from Pirates Lair?
post #7 of 10 Old 12-18-2013, 12:08 AM
madstrom's Avatar
Dan Vesel - VSRI
My V-Strom Accessories - Dan Vesel
http://madstrom.smugmug.com/Motorcyc...Backrest-L.jpg
madstrom is offline
post #8 of 10 Old 12-18-2013, 09:34 AM
nbsdave's Avatar
problem solved
OK, no problem with that, makes sense
now to answer his question -what would the passenger lean against?
nbsdave is offline
post #9 of 10 Old 12-19-2013, 09:37 AM
Juan Tanamera's Avatar
The passenger would lean against the top box. It all depends on the type of top box and how the mounting placement is. Some top boxes sit too far back and require the passenger to lean too far back to reach that back rest. Some top boxes may sit too far forward and the seating position becomes cramped. I would guess that most mounting plates would allow you to move the top case slightly forward or back to suit your needs.
I currently use a Givi E46 top case and it sits at just the perfect spot for passenger comfort. She always wears her motorcycle jacket and the padding in the jacket rests up against the hinge of the top box. For trips less than a few hours it's perfect.
If we were to do an all day ride, I would just strap a thin blanket or something on there to keep the hinge of the top box from digging into her back and to make it more level across her back. For really long trips I'll also have two drysacks that sit on top of each side case. This gives her armrests as well and there's no chance of her falling off when she inevitably falls asleep. This are not the best pictures, but hopefully convey the idea.
Orange Wee Member #420
Juan Tanamera is offline
post #10 of 10 Old 12-20-2013, 07:30 PM
There is one from Pirate's Lair. I just removed one from my new-to-me 06 Vee because I'm 6' 6" and kicked it every time I mounted or dismounted. The Pirate's Lair sticker was on the bottom.
Moe Trsyklist is offline
