Front brake rotor dimension specs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 12-14-2013, 10:46 PM Thread Starter
I've been searching online, but can't find the info that I need. I'm looking for the dimensioning specs of the front brake rotor for a DL1000. Specifically speaking, inside hole diameter, and then location & size for the bolt holes. Worse comes to worse, I could always go at it with a set of calipers, but I figured if someone had access to a specs sheet with the above dimensions, it would not only be easier, but more precise.
Thanks.
XC Rider is offline
