ignition switch problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 12-10-2013, 09:34 PM Thread Starter
Hi all,
I'm finding that I'm having trouble turning my key to get my bike started. It used to be super rare, but is getting worse, to the point I'm worried I will not be able to turn it and get stranded. I'm guessing it is based on some corrosion issue, unfortunately I've had to keep my bike outside for the last few years. I live in L.A. so it doesn't get rained on much but is often moist in the morning from dew. Is there any spray or lube that might help the problem, or do I need to replace the ignition? Thanks!
-Mark
landscapegoat is offline
post #2 of 13 Old 12-10-2013, 09:37 PM
tiller4me's Avatar
Many will chide in with their varied opinions, but WD40 is your friend. My locksmith recommends it, and since he has been in business for over 25 years I trust him.
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #3 of 13 Old 12-10-2013, 11:11 PM
Lubricate it.
I've used WD-40 sucessfully. I've also used graphite, silicone lubricants, CRC 3-36, 3in1 oil, and several others.
Any light weight lubricant will do the job. Your ignition doesn't get much moisture in it so even if you use graphite it will probably be fine for years.
Moe Trsyklist is offline
post #4 of 13 Old 12-10-2013, 11:13 PM
Even in an ignition?
Big B is online now
post #5 of 13 Old 12-10-2013, 11:48 PM
Different locksmiths have different opinions. One where I used to work likes WD40.
post #6 of 13 Old 12-11-2013, 01:46 PM
chicago's Avatar
Happened to me on a trip with my DR650. Key wouldn't turn. I was almost ready to by pass the ignition but I gave it a shot of Dupont Chain Saver with Teflon cause that's what I had. Instant fix, no problems to date. Most lubes would probably work.
chicago is offline
post #7 of 13 Old 12-11-2013, 06:43 PM
Craig Jackman's Avatar
A LITTLE squirt of WD40 made a big difference on mine.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #8 of 13 Old 12-15-2013, 11:14 AM Thread Starter
thanks for the feedback
Thanks, everyone. My concern was gumming up the mechanism and making matters worse. I tried WD-40 and seems to have worked.
post #9 of 13 Old 12-15-2013, 11:31 AM
Key and pin wear
Another consideration is key and pin wear. As years of use accumulate the key will wear down and the edges will become soft sometimes necessitating a jiggle while you turn approach. If you have the key code, you can get a duplicate key made with the original peaks and valleys, as opposed to duping from a worn key.
Fat Boy is offline
post #10 of 13 Old 12-15-2013, 02:03 PM
If he thinks corrosion is the problem then
Water Displacement Formula 40 is a very good choice
It leaves a hard waxy film which protects against moisture but does attract and hold grit
richw is offline
