repairing my boot sole - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 12-02-2013, 12:24 PM Thread Starter
I had a blow out on my alpine stars goretex boots. the sole on my left one separated and now hangs like a duck bill. shoe repair shops are very rare these days so what and how do you guys fix them?
icnxpln is offline
post #2 of 10 Old 12-02-2013, 12:27 PM
2 words - GORILLA GLUE
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #3 of 10 Old 12-02-2013, 12:47 PM
bleedgrn's Avatar
Because of the investment of the boot (mine are $400 bucks) I use a local cobbler to do repairs. My local cobbler is Bear Shoe Works in Superior, Wisonsin. They have repaired expensive wading boots for me as well as resole others. Much cheaper than the replacement cost. Using glue may work temporarily but would hate to have a problem away from home.
Keep Calm, Fly-fish
L2 Glee White- birthday 17 JAN 13
Farkles last to first: MFW Hwy pegs, Russell Daylong, Givi 3D604 tank bag, Motech Pegs, Madstad bracket&adv windshield, Tuono mirrors, Uclear HBC200 headset, E45 topcase, Cree driving lights w/Motech brackets,14T Sprocket, bar riser, E21 panniers, Stich heated grips/outlet, EB PC8, RR Fork Brace, Kouba link, Barkbusters, SW-Motech Centerstand/Skidplate/Crash Bars.
bleedgrn is offline
post #4 of 10 Old 12-02-2013, 01:46 PM
jdad's Avatar
If you cannot locate a cobbler, find a saddle shop, they can glue and stitch it back together. If you have no other choice, place screws around the tip of the sole about 2" apart. This is commonly found on fire boots (Whites) where stitching and glue do not hold up to the heat.
jdad is offline
post #5 of 10 Old 12-02-2013, 07:14 PM
I think the glue of choice is "barge glue."
Not a cobbler - just paying it forward.
phoenixsteve is offline
post #6 of 10 Old 12-02-2013, 09:28 PM
yankeepac's Avatar
have used barge cement on every type of boot out there, hiking boots, climbing boots, my Birkenstock. always holds up nicely.
Ride History
2005 DL 650
1989 TREK 850 Mountain Bike
1974 SCHWINN BANANA SEAT (probably worth more than the wee now, oh well)
yankeepac is offline
post #7 of 10 Old 12-02-2013, 09:55 PM
Tall Man's Avatar
I once used a bead of Liquid Nails to effect a field-expedient repair. The cobbler complained about its adhesive strength when I took the footwear to him for a proper repair. Based on his feedback, I'd actually caution against using construction adhesive unless no other option is available or practical.
Tall Man is offline
post #8 of 10 Old 12-04-2013, 02:48 PM
The old standby is Barge Cement. That is likely what a cobbler or saddle maker will use.
deuce is offline
post #9 of 10 Old 12-04-2013, 06:01 PM
hunt1moore's Avatar
I think you can send them back to Alpinestar.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #10 of 10 Old 12-05-2013, 12:26 AM
resole.com specializes in repairing m/c boots
Tony K is offline
