Heated Grips! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 11-15-2013, 11:30 PM Thread Starter
Coyteo's Avatar
Heated Grips!
What say you, Stromtroopers!
Think I may invest in some soon.
Coyteo is offline
post #2 of 14 Old 11-15-2013, 11:57 PM
MeefZah's Avatar
I say, good call.
They are nice in damp and cool weather. Not really a total game changer in freezing weather though, as the cold just kind of seeps in everywhere else.
I like Oxford, which offers several types of grip options, around $80.
If you opt for Oxford, get the newest version (v.8 controller), which offers 5 heat settings, an auto off feature that actually works (unlike their previous ones), and a more simple wiring harness (does away with an underseat box and some wiring and literally becomes a two wire hookup).
Other options are Hot Grips, Symtex, Twisted Throttle, Suzuki OEM, probably others. Of these I have also used the Symtex ones, which are inexpensive and go under your existing grips. They are decent, though the included switch is prone to failure. I hear the OEM ones are not terribly warm but I have no experience with them.
Oxford sport grips with V.8 controller:
MeefZah is offline
post #3 of 14 Old 11-16-2013, 12:19 AM Thread Starter
Coyteo's Avatar
That is exactly what I was looking at. Did you install them yourself or have a dealership do it? I have never worked with grips before.
Coyteo is offline
post #4 of 14 Old 11-16-2013, 12:34 AM
Stromtrooper.com Sponsor
Satch's Avatar
Originally Posted by MeefZah View Post
I say, good call.
Add some hand guards and the game will change. Heated grips without hand guards is like wearing a heated vest under your mesh jacket.
P.S. Just once I'd like to see a poorly composed out-of-focus photo from you!
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #5 of 14 Old 11-16-2013, 12:47 AM
I had Oxfords and they make a nice product, but nothing gets hotter than the Symtec grips IMHO......inexpensive too.
post #6 of 14 Old 11-16-2013, 01:05 AM
+1 on the heated grips hand guard combo. I got a pair of trackside grips from cycle gears last year for around $40. Not the best, I think the rotary switch might be the first component to fail & the R-side always gets warmer than the L.
I was able to install mine using the included manual and some grip glue. If you've never pulled the bar ends, it might be worthwhile to look at its assembly in the manual.
2013 DL650A
Sicha is offline
post #7 of 14 Old 11-16-2013, 02:49 AM
MeefZah's Avatar
That is a good point. They are on my list.
Thanks.... :mrgreen:
I did it. It is stupidly easy.
MeefZah is offline
post #8 of 14 Old 11-16-2013, 09:51 AM
I say, good call.
Did you use the factory heated grip connector or another connection point?
I like what I hear/read about the Oxfords but that controller doesn't look pleasing to my eye. It will probably be what I go with because the other switch/control options are all about an extra $50.00 or more.
BigEasy is offline
post #9 of 14 Old 11-16-2013, 10:35 AM
MeefZah's Avatar
Just go right to the battery. In my mind, the only reason to wire your grips in to the factory connection is to get the benefit of switched power to shut the grips off when the bike is off. With the new Oxfords there is no reason to wire it into the factory connection because the grips will turn themselves off.
The switch is smaller than the OEM switch, but obviously not as compact as a DPST switch that you might get with the Symtex brand. I think it looks fine, regardless.
MeefZah is offline
post #10 of 14 Old 11-16-2013, 08:32 PM
biker128pedal's Avatar
They cost more but I went with the Hot Grips and Heat Troller controller. The grips are garanteed not to burnout. Work great. I got them from Lockett. I used velcro to mount the sealed controller. But have it panel mounted now. Hot grips has a removable version now.
Vstrom 650 ABS
'09 DR650
'07 Vulcan 900 LT
biker128pedal is offline
