Topcase and now have buffeting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-23-2007, 11:01 PM Thread Starter
I was pleasantly surprised with my new DL1000 that it didn't buffet as much as I'd anticipated. Well, I installed a Give 36NJ topcase and now I do have buffeting. Not too bad, but enough I'm thinking about trying to eliminate it.
By the way, I rode the bike today without the topcase to confirm no buffet. Yep, the top case does it.
I know there is a lot of info on this forum and others regarding buffeting, but I'm wondering if anyone did NOT have any, but then did after installing a topcase, then what they did to cure the problem.
Thanks for any help in my quest!
adVentureMan is offline
post #2 of 12 Old 08-24-2007, 12:25 AM
Brasstax's Avatar
Get one of the new STROM WINGS by SWMOTECH from Twisted Throttle.
It mounts on top of any GIVI case or helmet
Brasstax is offline
post #3 of 12 Old 08-24-2007, 09:14 AM
Your findings somehow confirm what more and more strom owners are figuring out: the turbulence comes from under the fairing, not from its top. Adding a top case could somehow alter the general aerodynamics in a way that makes it draw more air from under the fairing, therefore, increase turbulence.
spidrgr is offline
post #4 of 12 Old 08-24-2007, 09:23 AM
Below is a photo of my DL1000K6. This is the configuration that I ride all the time.
The windshield is stock, but has a Laminar Lip Touring Lip and the bottom is spaced out 15 mm.
I do believe that the Aerostitch Tank Panniers and the Large Tankbag from Frank Thomas take care of all the errant wind.
When I'm riding in quiet air, like in the morning on my 50 mile ride to work, the area where my head stays is very quiet and calm. Yes, when there is dirty air, I do feel it, but this is a motorcycle.
fl_strom is offline
post #5 of 12 Old 08-25-2007, 01:43 PM Thread Starter
Originally Posted by fl_strom View Post
...The windshield is stock, but has a Laminar Lip Touring Lip .....
I've heard that "lip thing" once or twice. Tell me more about it, sounds interesting.
post #6 of 12 Old 08-25-2007, 02:12 PM
V-Tom's Avatar
I believe he said top case which is behind him when riding, not a tank bag.
I know it might be a matter of wording, but I will bet it isn't that the turbulance comes from under the tank, but that the stream of air coming from under the tank interacts with air coming from the air above and besides and under the windshield and from air reciruclating behind the windshield and this causes the turbulance. Little changes in attitude of the bike, wind, etc can make total changes in the setup that works. It might ibe in this case the topcase weight affects the attitude of the nost a bit, or that it changes the flow of air that is recirculating around him and that changes the interaction.
It likely won't be any one thing that fixes it for everyone.
I'm 6'2" tall..When I added a Corbin seat to my 650 I had to change everything around. I have the Madstad with the original windshield attached in the suggested (middle) position to the bike. For me pulling it all the way up and back worked best. With the Corbin (and the extra inch or so higher I sit) I found for me the windshield in the lowest adjusment allowed by the madstad worked best.
(Me new Givi + Madstad seems the best, though.)
..Tom
SMIDSY detailed report.
V-Tom is offline
post #7 of 12 Old 08-26-2007, 09:21 PM Thread Starter
Righto Buddy, right after you do it! :rolleyes:
post #8 of 12 Old 08-26-2007, 09:25 PM Thread Starter
Thanks Tom. I forget if I mentioned it here already, but I ordered the Madstad bracket. Should be here this coming week. So I'll fiddle around with that and the stock OEM windshield. I hope I don't end up with a replacement windshield! I need those pennies for other items!
post #9 of 12 Old 08-26-2007, 09:37 PM
dmf109's Avatar
I saw a 'Strom today with one of those things (and no top case). It's...um...a unique look .
dmf109 is offline
post #10 of 12 Old 08-26-2007, 10:36 PM
JohnR's Avatar
NASCAR Car Of Tomorrow, Today!
At the end of the day if you've touched the soul of another and gained knowledge of at least one new thing, then you are truly successful.[I][/I]
JohnR is offline
