Winter - storing chemicals, aerosols, and solvents? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 11-12-2013, 01:12 PM Thread Starter
exzachtly1's Avatar
So I've only been riding motorcycles (and doing all of the maintenance related to them) for a little over a year now. I've started amassing a collection of solvents, chemicals, and aerosols, and am wondering what to do with them over the winter. My garage is unheated and I don't know if any of them will be ruined in the freezing temps.
I suppose I could just bring the more expensive stuff inside (plexus, chain lube, cable lube, bike cleaner, etc. - these items alone add up to a pretty penny), but am not sure if it matters or not. I just don't want to have to bring EVERYTHING in.
I've read most of the labels on the more expensive items and the only stipulation seems to be about not storing them in hot temps - but I have to imagine the cold can be bad too??
...anyone have any thoughts on the matter? What do you guys do?
2012 V-Strom 650 Adventure
1982 Suzuki GS650L
exzachtly1 is offline
post #2 of 11 Old 11-12-2013, 01:20 PM
Banned
where do you live at, and how cold does it get?
Here in the PNW it doesn't get very cold, I leave all the chemicals out in the unheated shed without any trouble at all.
Rashnak is offline
post #3 of 11 Old 11-12-2013, 01:29 PM Thread Starter
exzachtly1's Avatar
Northeast Ohio. I would say the average temps in the winter are around 20-30 degrees, with some extreme days getting down into teens or lower. Sub zero only ever factors in when there's wind chill involved
Of course, I'm sure it is generally a few degrees warmer in the garage as long as the door remains closed. Have to imagine that the sun hitting the roof would warm it up slightly inside.
1982 Suzuki GS650L
post #4 of 11 Old 11-12-2013, 01:59 PM
Frantic's Avatar
Any type of lube or solvent should be fine. It will just thicken with the cold and return to normal when warmed. Waxes, polishes and anything with water in it would probably do better above freezing.
Some of the plastic containers will become very brittle when subjected to cold as well.
Frantic is offline
post #5 of 11 Old 11-12-2013, 02:09 PM Thread Starter
exzachtly1's Avatar
Hmm, based on this I may be putting together a milk crate to bring in! Hate to see any of that stuff go to waste.
1982 Suzuki GS650L
post #6 of 11 Old 11-12-2013, 03:24 PM
That's exactly what I do. My milk crate is full, on my workbench and ready to go to the basement.
I have found that some of the aerosols(especially Plexus & spray cleaner waxes) tend to come out in a "stream" rather than a "spray" if they have gotten real cold over the Winter.
I live in my own little world, but it's OK, they know me here.
SlingBlade is offline
post #7 of 11 Old 11-12-2013, 03:43 PM
Plastics also tend to crack if frozen/liquid in them freeze, think spray bottle nozzles and pickup tubes. I would rather need to buy a new bottle of xyz than have some mixture of chemicals in the house Just because it is safe/stable in its bottle alone, what if 2 of them mixed... that said, I never bring in any of my cleaners, they are in a metal cabinet in the garage all winter, southern Maine gets to single digits
danhikeski is offline
post #8 of 11 Old 11-12-2013, 03:58 PM
nuke's Avatar
I bring all chemicals and cleaners inside during our winters. Temps outside here may go to -20 F or occasionally a bit cooler...garage, maybe -10 F. Not going to use them from mid December till mid March anyway when the bike is parked. Wow 31 degrees here now with snow flurries and cooler tomorrow morning. Will still be riding unless ice and wet salt on the road into December.
2012 DL650/EXP (fox orange)
nuke is offline
post #9 of 11 Old 11-13-2013, 11:54 AM
V-Strom Ry's Avatar
I've always left all my lubes and cleaners out in the garage in the winter. It certainly gets below freezing, although not quite as cold as the great outdoors. The only I noticed that was somewhat permanently changed by freezing was my car wash liquid. Of course, when they're really cold most of these spray cans of stuff don't work very well - the pressure gets too low and the liquid too thick due to the cold - but they work fine again once warmed up and given a shake.
V-Strom Ry is offline
post #10 of 11 Old 11-13-2013, 12:47 PM
I've had the same can of wd40 riding in my truck toolbox for three years and it's fine. I live in the same region as you and all that's ever happened is some car wash soap turned into slush... it was melted when spring came around though. Keep in mind all this stuff has to be shipped to the store through the winter - do you think they do it in a heated truck?
05 DL1000 (Black)- Death by horse 7/13
05 DL1000 (Blue)- Adopted 3/14
ShadowNWPA is offline
