Oxford Heated Grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 11-05-2013, 09:39 PM Thread Starter
Oxford Heated Grips
I did a search and read quite a few different threads but just didn't get an answer and was hoping that someone could help out. I would like to add heated grips to my 2012 VStrom and have decided to get Oxford's. However, that there are quite a few differennt ones out there and I am wondering which one to get based on length. I found an Oxford product page that lists 4 different models. The Touring, Adventure and Sport all look good. They are all slightly different lengths and it appears that the Sport can be trimmed. Do you guys have any suggestions??
caprock is offline
post #2 of 22 Old 11-05-2013, 09:58 PM
The stock grips are 4-1/4 inches long. That's what you want. The bars are 7/8" or 22mm.
post #3 of 22 Old 11-05-2013, 10:07 PM
Rainman901's Avatar
Touring
I have a 2012 Wee also and I purchased the Oxford Premium Touring.
I like 'em.
Sent you a PM with a link from where I got mine.
Ray
DL650AL2 "WEE" Strom, (I'll never call it a Glee, noob or not).
Grip Puppies; SW-Motech Center Stand; SW-Motech Crash bars; Touratech Skid Plate; Bike Viz Bullets; Stebel Nautilus and a Front Fenda Extenda. Ebay special Brake and Clutch Levers; Wolfman Explorer Lite tankbag; Givi V46 TopCase.
Rainman901 is offline
post #4 of 22 Old 11-05-2013, 10:20 PM Thread Starter
The link I posted didn't go directly to the grip page like I intended ( grips are on page 11 ). The 4 grips that I mentioned fit 7/8" bars. So based on the reply above about 4.25" works out to be 107.95mm (this is a correction to previous bad math). The tour grips show to be 120/110mm, adventrure grips 132/122 and the sport show to be 123/114. Is there a diffence in length between the left and right side grips? Or do you think the second smaller number is a trimmed length? on the web page only the sport grips show to be trimmable.
caprock is offline
post #5 of 22 Old 11-05-2013, 10:22 PM Thread Starter
I like 'em.
Ray
Did you have to trim your grips length or is the factory length ok?
caprock is offline
post #6 of 22 Old 11-05-2013, 10:46 PM
NWArkie's Avatar
If you do have to trim them, it ought to be minimal or you'll cut into the heating element.
NWArkie is offline
post #7 of 22 Old 11-05-2013, 10:52 PM
Doesn't 4.25 inches work out to 108mm?? That means the Oxford grips are too long. I noticed on TwistedThrottle.com that the 2012 VStrom 650 does not appear in the list of compatible bikes for these grips. I've been looking at these too- my hands have been freezing the past week!
SteveFoy is offline
post #8 of 22 Old 11-05-2013, 10:53 PM
4-1/4" is 10.8cm or 108mm. Unless a grip has specific trimming instructions, do not cut them. 110mm is the metric length you want. 2mm is a miniscule amount.
post #9 of 22 Old 11-06-2013, 12:01 AM Thread Starter
Steve, thanks for the math correction.
caprock is offline
post #10 of 22 Old 11-06-2013, 12:08 AM Thread Starter
Greywolf, Rainman indicated that he got the touring grips and based on what you are saying, those are probably the only ones that will fit without trimming, is that correct? All the Oxford grips that are listed have two dimensions. The touring is listed as 120/110mm. Do you know why there would be two lengths listed? Also, is it safe to presume that the Vee & Wee grips are the same length?
caprock is offline
