Drained Battery Ignition Technique? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 08-16-2007, 10:40 PM Thread Starter
dante662's Avatar
So I come home from work early today round noon, park the bike, then jump in my car to go pick up some friends and spend some time out and about.
I get back in around 8, to find that I stupidly left the ignition in the "park" setting, not the "lock" setting...and the brake light has drained my battery to the point I can't turn over the engine.
I have an idea of what to do...luckily my parking lot has a slight downslope. So, I'm gonna put it in second, turn the key to "On", get the engine kill switch on, and push forward until I'm got some momentum and just pop the clutch and hope the thing starts.
Does that sound about right? About how long do you think I should keep the motor running to charge up the battery again? Will it charge if I just idle the engine? I only ask because tomorrow morning I have to get to work, and can't ride around boston area traffic waiting for it to charge up...but I can let it sit in our secure parking structure and idle it for a while.
Any thoughts/tips/suggestions appreciated! It's a K7 Wee, by the way.
dante662 is offline
post #2 of 13 Old 08-16-2007, 10:53 PM
JohnR's Avatar
Sounds pretty good, really. I'd suggest riding it 20 miles or so. That should recharge it for tomorrow. I'm not sure about idling it, as most bikes I've had require about 2500 rpm to really get the generator working. The tell tale sign is being able to see your headlight strength increase against the garage door as the revs climb. My Vee doesn't seem to have that trait. You might try pointing the lights at a dark wall once it fires and slowly build the revs from idle to see if the charging system "comes on" at a certain rpm.
At the end of the day if you've touched the soul of another and gained knowledge of at least one new thing, then you are truly successful.[I][/I]
JohnR is offline
post #3 of 13 Old 08-16-2007, 11:09 PM
liljoec's Avatar
It has been my experience with motorcyles that it is hard on them to charge up a dead battery using the bike's charging system. Basicly, the charging sytem didnt put out much more than it needed and thus required it to constantly work overtime. But, that was on older bikes. maybe the strom puts out more juice and can handle the load.
I know if it were me, I'd run to wal-mart tonight buy a charger and run it on it tonight. it'll be ready by morning.
2007 DL650
liljoec is offline
post #4 of 13 Old 08-16-2007, 11:24 PM
+1 lil joe...........charge it tonight and it will be ready for an early morning rip
Although since the battery did not have time to completely discharge, it may just come up enough to start the bike in the morning.
Good luck.
06 DL1000 Red -
"shifts smoother with those mirror extenders!"
00 xr650l -
01 TW200 - resort cruiser
tucsonstrom is offline
post #5 of 13 Old 08-17-2007, 07:19 AM Thread Starter
dante662's Avatar
So after five failed attempts, I've taken the battery out and I'm now searching online for an appropriate charger. I know the max charge rate is 5A per 1 hour, nominal is 1.2A per 10 hours, either one works for me, but where should I pick up such a thing? Can I go to autozone and just grab a car battery charger?
dante662 is offline
post #6 of 13 Old 08-17-2007, 08:05 AM
mtlee's Avatar
I've been using an 'automotive' charger for everything from my motorcycles to my boat to my lawn mower. As long as the voltage is correct, you should be fine (i.e. the charger is meant for 12V systems). The 'Amps' rating is more about speed of charging. A lower charge rate (2A on mine) takes longer; slower typically is a more efficient charge chemically speaking.
'07 DL650 ABS
'04 Yamaha V-Star 650 Classic Silverado (gone)
'04 Yamaha TTR225
'03 BMW F650GS (wife's)
'92 Honda XR250L
'86 Honda VT500c (gone)
mtlee is offline
post #7 of 13 Old 08-17-2007, 08:32 AM Thread Starter
dante662's Avatar
Gotcha. I just got a 1.5A charger from autozone, it's nice because it'll also double as my winter-storage-battery-maintainer once I put the bike away for the winter.
I just wish I was able to pop-start the thing, would have been a nice skill to have mastered, just in case.
dante662 is offline
post #8 of 13 Old 08-17-2007, 10:23 AM
liljoec's Avatar
That skill will come with wisdom and experience young grasshopper. haha. just playin.
but on some real, if it was totally dead, it would not have started by push-starting. So, you may not have been doing anything wrong.
2007 DL650
liljoec is offline
post #9 of 13 Old 08-17-2007, 10:23 AM
1.5A constant is too much for a maintainer. It will cook your battery. You need a battery minder or battery tender that will read the charge state and turn itself off or down when the battery is fully charged. It may even be too much to charge the battery after the discharge. 1A or 1.2A rating was the recommendation IIRC. Check the manual.
post #10 of 13 Old 08-17-2007, 10:25 AM
Go ahead...try it with a charged battery, it will work easily if you do it in second gear. I doubt you wil ever be able to push it fast enough to ''bump start'' it with a dead battery though. Remembrer, the fuel pump has to be able to charge the whole injection system before the engine can start.
Personally, I would have tried to jump start it with a car! 12 volts is 12 volts, no matter where it comes from.
spidrgr is offline
