SW moteck center stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 11-01-2013, 03:15 PM Thread Starter
Hi, my name is Kevin And I bought a new 2012 Vstrom 650 Adventure a couple of weeks ago. I am going to order a SW moteck center stand through Twisted Throttle but have a question to ask everyone. They offer a spring tool for sale for the center stand, is this tool necessary or can I get by without it?
Thanks Kevin
Kevin D is offline
post #2 of 13 Old 11-01-2013, 03:31 PM
Did not need it for mine. two screwdrivers and a little grunting.
2012 DL650A; daily commuter http://www.flickr.com/photos/[email protected]/sets/72157633330697107/
Sold: 2003 SV650: weekend canyon carver http://www.flickr.com/photos/[email protected]/sets/72157630515234266/
fragile_this_side_up is offline
post #3 of 13 Old 11-01-2013, 07:02 PM
chicago's Avatar
A large screwdriver works
chicago is offline
post #4 of 13 Old 11-01-2013, 08:08 PM
bleedgrn's Avatar
Basic tools only. Make sure you use some axle grease to lubricate the pivot shaft. Use my Motech centerstand daily. Best part is stability and maintenance. Usually lube my chain at the gas pump.
Keep Calm, Fly-fish
L2 Glee White- birthday 17 JAN 13
Farkles last to first: MFW Hwy pegs, Russell Daylong, Givi 3D604 tank bag, Motech Pegs, Madstad bracket&adv windshield, Tuono mirrors, Uclear HBC200 headset, E45 topcase, Cree driving lights w/Motech brackets,14T Sprocket, bar riser, E21 panniers, Stich heated grips/outlet, EB PC8, RR Fork Brace, Kouba link, Barkbusters, SW-Motech Centerstand/Skidplate/Crash Bars.
bleedgrn is offline
post #5 of 13 Old 11-01-2013, 08:37 PM
Originally Posted by bleedgrn View Post
... Best part is stability and maintenance. ...
I had the dealer install centerstand before I would close the deal to buy it. It is essential for chain-lubing and other rear-wheel maintenance.
HOWEVER: For "stability", it is well known (basic physics) that 'Three points make a plane' Using the side-stand is FAR more stable. People who live in earthquake-prone areas are encouraged to use the side-stand to prevent tipovers during a geological event.
BruceP is offline
post #6 of 13 Old 11-01-2013, 08:56 PM
bleedgrn's Avatar
Technically using the "three points make a plane" makes my point (two feet on stand, front wheel). I do understand what you mean by leaning weight against a point, or "triangular stability". Without trying to start a physics debate I typically use the center stand when leaving my bike for the day. With my bike lowered, my "kickstand" doesn't allow much lean and appears less stable.
Happy to hear you bought a center stand.
Keep Calm, Fly-fish
bleedgrn is offline
post #7 of 13 Old 11-01-2013, 09:01 PM
Thanks Kevin
I found an old file without a handle and the narrow part which the handle fit onto was bent. It turned out to be the perfect tool. You want leverage and control for this install.
pacaver is offline
post #8 of 13 Old 11-01-2013, 09:39 PM
They offer a spring tool...
A simple way is to just use a piece of wire or cord with a knot/loop in one end and passed through a short piece of PVC pipe on the other for a handle. Then just use brute strength to stretch the spring. They're not all that strong; it's really just a matter of having a no-slip way of grabbing it.
After an episode working on my first V-Strom, I now keep an old shortened cam-type motorcycle tie down in my tool box and use it EVERY TIME I work on the bike with it on the center stand. Yes, a center stand is necessary and stable for working on the bike, but just be aware that just a small amount of rotational torque on a bolt in the wrong direction easily transfers enough torque to the bike to rotate it forward off the centerstand.
The time that happened to me, at least I was on the right side with my torque wrench and the bike (thankfully) fell to the left. But I ended up having to do some fiberglass patch work on those brittle and ridiculously expensive plastic fairing pieces.
Lesson learned, now whenever the bike is on the centerstand, I hook one end of the tiedown onto the cross-member of the stand, loop the other end through the front wheel and snug it down, so the centerstand can't flip up if the bike tries to roll forward.
JET
JET_V-Strom is offline
post #9 of 13 Old 11-02-2013, 01:37 AM
I installed the SW Motech centerstand on my DL650A. I just used a long screwdriver to pry the springs on. Don't pay for the tool.
deuce is offline
post #10 of 13 Old 11-02-2013, 01:46 PM
Shoestring works great.
