12v from where? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 10-29-2013, 03:46 PM Thread Starter
12v from where?
Hi all. I have a set of Acerbis handguards that can take a led strip and I'm thinking of fitting one. I can do it , but I'm also afraid of making some mistake with the voltage. The strip needs 12V and I would appreciate if smb could tell me exactly from whitch cable to give power to the strip. Has to be near the handguards.
Memos is offline
post #2 of 22 Old 10-29-2013, 04:05 PM
tmcgee's Avatar
I'm planning on using amber color and wiring the LEDs to the front blinkers. If you're looking for running lights, there are plenty of hot sources to tap in the fairing.
tmcgee is offline
post #3 of 22 Old 10-29-2013, 04:12 PM Thread Starter
Yes, I'm thinking always on. Could you be more specific on which wires to choose? Headlights maybe? I'll be using two of these.
Memos is offline
post #4 of 22 Old 10-29-2013, 04:19 PM
Scotch connector you imaged are ridiculous especially outdoors
You need to get real crimp push on insulated connectors before the blinker connectors so you can take the thing apart.
Note LED's have polarity so you have to connect them positive to positive. You won't do any damage connecting them backward they just wont go on then do it the other way
richw is offline
post #5 of 22 Old 10-29-2013, 04:29 PM Thread Starter
Polarity noted, and also no ridiculous connectors! What about soldering and that thermo-constricting meterial for the connections?
Is there a relatively 'easy' connector from which to get power?
Memos is offline
post #6 of 22 Old 10-29-2013, 04:41 PM
tmcgee's Avatar
Definitely stay away from those connectors, they don't weather well.
Can't tell you specifically where to get 12V, but would prolly avoid the headlights since there are two circuits there. Personally, I run a small power distribution hub to the fairing from the battery, but that's just geeky techie me.
Thinking out loud, tapping into the heated grip connector may be easiest. It's ignition switched and has both hot and ground wires.
tmcgee is offline
post #7 of 22 Old 10-29-2013, 05:01 PM Thread Starter
Ok,heated grip connector sounds just fine....ehm...where is it????
Memos is offline
post #8 of 22 Old 10-29-2013, 05:33 PM
blue72beetle's Avatar
I can't post a link or picture, but do a google search for Posi-Tap. It's a much better connector for tapping into wires.
-Andy-
-2006 DL650-
blue72beetle is offline
post #9 of 22 Old 10-29-2013, 05:42 PM
what year is your Wee?
Current: '12 Dl650, '06 ST1300, '89 Transalp, '84 XL350R, '07 TRX350TM,
DownOnTheFarm is offline
post #10 of 22 Old 10-29-2013, 08:51 PM
Dude
TURN SIGNALS
richw is offline
