extra screws after maintenance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 08-14-2007, 05:24 PM Thread Starter
mistanfo's Avatar
Checked my air filter and replaced my plugs. Removed more or less the entire cowling, and the fuel tank. I have it all back together, but have 2 phillips head, black screws remaining. Approx 1/2" long, I believe that they are called pan head (raised dome). Any ideas?
K6 Wee, '97 Miata (track toy), '03 TDI Jetta (economy champ when 2-up or greater).
mistanfo is offline
post #2 of 8 Old 08-14-2007, 05:40 PM
TomT's Avatar
Send a message via AIM to TomT
Sound a lot like the two screws I removed Sunday while installing my Madstad Bracket. Could they be from the windshield mounting covers?
"Since I am about as mechanically inclined as a Sea Otter (which means I can use hard things to smash open softer ones), I was delightfully surprised when the bike started and ran perfectly after the PCIII install."
2005 DL1000 Blue (new 7/07)
TomT is offline
post #3 of 8 Old 08-14-2007, 06:03 PM
There are two screws inside the vents in the fairing. If those are not the ones, take them out and the seven plastic rivets holding the chin piece under the headlights. Take off the chin piece and there are two screw holes exposed under the side cowls near the vents. It's #5 in the picture.
post #4 of 8 Old 08-14-2007, 06:17 PM
MightyShep
If you inverted the air box cover they may have fallen out of there. Remember the 6P's (Prior Planning Prevents Piss Poor Performance)
post #5 of 8 Old 08-14-2007, 06:21 PM
randyo's Avatar
I was once told a good mechanic always has leftover parts and doesn't need a torque wrench, just tighten the fastener till the head snaps off then back off a half turn
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 8 Old 08-14-2007, 08:43 PM
Colin's Avatar
I think greywolf has the answer. I had two left over just like that. I puzzled over them for quite awhile because they looked just like the ones from the little vents on the fairing.
Found the spot months later when I had the whole thing apart again to do my plugs and air filter and noticed the #5 spot for them.
Colin is offline
post #7 of 8 Old 08-14-2007, 08:52 PM Thread Starter
mistanfo's Avatar
I'll have to check #5. I know that the 2 screws in the vents are there, and all eight of the airbox screws were put in. guess I'll take it back apart tomorrow during the daylight.
mistanfo is offline
post #8 of 8 Old 08-15-2007, 08:04 AM
Jeff Kushner's Avatar
How about the two screws that hold on the PAIR valve? Did you remove that bracket when you removed your tank?? Those are the screws that face upwards.
Jeff
Present only:
My VStrom 1000 K7
Stock bikes: a
purple '74 RD350 in great shape,
'72 H1,
1975 GT550,
All-original 1975 H2 750 triple (purple of course),
Modified bikes:
1974 H2 750(my go-fast), a scary fast & fully ported street machine!
'82 Yam 650 Turbo- running 18PSI, Be sure to be pointed where you want to go!
'75 GT550 built up & ported,
'75- H1 wrist-rocket- HOLY GOD ALMIGHTY!
'75 S1 Kaw 250 baby triple w/ lifted and ported 350cc cylinders/28mm flatslides
To-Restore list: '72 H1, 1-'75 H1, 1974 GT750
Jeff Kushner is offline
