Controlling camera shake using RAM mounts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 08-13-2007, 09:15 AM Thread Starter
rhbell's Avatar
I've been preparing for my upcoming BC trip and experimenting with using my P&S Canon 710 to take some video along the way, using a handlebar mountd RAM mount.
I've found that stills work very good and have taken quite a number of keepers - problem is with video, at ay resolution, is there is a lot of shake due to minor road vibrations coming through the handlebars. I also tried my older but smallish camcorder with somewhat same but lesser results. Both hae optical stabilization and it's on. In addition, whether using a 5" or 3" mounting arm seems to make little difference, same with whether the camera has the lens tube e/w 1A and CP filters on.
I don't want to go to a ring mount on the gas tank as I have a FAMSA tank set and don't want to give that up, other than that, and purchasing a new camcorder and lipstick cam, options are open. (I have discovered money talks - when I take my credit card out lately I seem to hear - "oh [email protected]$%^, not again")
Wondering if anyone has any suggestions - mounting, technique etc that might help reduce and or eliminate the shake. Appreciate advice from those who've been down this road before.
Thanks and safe riding
Bob
Necessity may be the mother of invention, but desperation is it's father........... (Bell)
'06 DL650
rhbell is offline
post #2 of 7 Old 08-13-2007, 10:15 AM
MightyShep
You're never going to get rid of camera shake on that mount. You've placed all the weight high on a stick, mounted to a moving platform. It's always going to shake. The best way to get good video is a bullet cam. For an inexpensive solution check out Oregon Scientific's ATC-2k helmet cam. It's about the sizee of a small flashlight and is a self contained unit that records onto SD flash memory. The cheapest I've seen is $88.00 online.
post #3 of 7 Old 08-13-2007, 11:10 AM
BloatedBird's Avatar
Im shocked those are only 88 now shep I might have to look into one, this could be great for riding and snowboarding :mrgreen:
If its a constant vibration the only thing I can think of is trying to find ways to isolate the mount, padding of somesort perhaps? it wont get rid of the problem but if you can get a wide enough mount with some kind of foam between it and the bar it might take the vibration down a littke.
1997 CBR600F3 sold
1998 CBR1100XX sold
2007 Wee-Strom
"It's the game of life. Do I win or do I lose? One day they're gonna shut the game down. I gotta have as much fun and go around the board as many times as I can before it's my turn to leave."
BloatedBird is offline
post #4 of 7 Old 08-13-2007, 11:41 AM
Heavy's Avatar
What about a remote cam that plugs into an existing recorder? I know this is expensive but it certainly conveys the idea.
http://www.viosport.com/store/custom...scout_overview
DL1000K6
Heavy is offline
post #5 of 7 Old 08-13-2007, 11:45 AM
Jblk9695's Avatar
I've tried everything to cure the vibrations on a mini DV, from isolation mount using special rubber standoffs to urathane dampening and the only solution is to use a bullet cam and just use the mini DV as a tape deck. Check on ebay for helmet cams or bullet cams, should be some available for around 120 bucks.
Jerry
Second childhood, heck, I'm still in the first. 72 going on 25
Added an 09 Yamaha FZ6 for my birthday
Sold the FZ6 and got a Triumph Tiger 800
Now have a Triumph Bonneville and an 09 Wee
Retired and lovin it
1945 Wife
Jblk9695 is offline
post #6 of 7 Old 08-13-2007, 01:02 PM
Berserker's Avatar
I bought a Video Cam...
that has a vibration/camera (Canon) shake reduction mode that works really well and I mount it on a RAM mount that screws through the brake lever clamp.
I like it. The video is fairly shake free!
[U][URL="http://moveyourmoney.info/"]Move Your Money[/URL]
[/U]
Berserker is offline
post #7 of 7 Old 08-13-2007, 03:14 PM Thread Starter
rhbell's Avatar
Thanks - appreciated
Appreciate the advice. Perhaps later on when I find the additional $ to get a camcorder with AV inputs I'll try out a helmet cam. I have read a number of reviews about the all in one camera/recorder - some have been good, some not so good and think I'll let a few more members of John Q Public field test it first but certainly does look like a great idea for the motorcycle fraternity..
On a related note, I did find (today) a quasi cure while running an errand - reducing the arm height from 5 to 3" didn't buy me a lot - all tests were run on the same stretch of road at 80km/hr by the way but I did discover that repositioning the RAM so that the arm and steering head were more or less the same angle (rake) , and mounting the unit between the handlebar mounts took the jumpiness down quite a bit. I have the ball mounts for the master cylinder cover so may try that option in more detail as well.
Safe riding and thanks
Bob
'06 DL650
rhbell is offline
