Throttle Position Sensor Failure Rate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 10-13-2013, 04:35 PM Thread Starter
janiceclanfield's Avatar
Does anyone know for certain if Throttle Position Sensors fail fairly frequently? This is in regard to my earlier thread (rant).
I'm looking for proof positive, not rumour.
Anyone?
janiceclanfield is offline
post #2 of 13 Old 10-13-2013, 05:09 PM
I can say I've probably seen double figure in reports of replacements solving problems. However, those problems are almost always a failure to idle properly after a long ride.
post #3 of 13 Old 10-14-2013, 01:38 PM
bwringer's Avatar
They will all fail eventually. It's a pretty crappy sensor -- low quality and/or badly designed. Many riders simply haven't reached the mileage where their TPS fails, but it will.
Same as with the DL1000 fuel filter -- what brain-damaged engineer thought that a fuel filter the size of a pack of gum would be sufficient? It's absolutely doomed to clog.
bwringer is offline
post #4 of 13 Old 10-14-2013, 06:43 PM
trapperdog's Avatar
So why is it we rarely if ever see any STPS's go bad? They are basically the same as the TPS, getting abou the same amount of action. Are they going bad with the same frequency but no one is noticing as they perhaps send less relevant information to the ECU thereby causing less problems when bad? I've been pondering this for a while now.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #5 of 13 Old 10-14-2013, 07:34 PM
randyo's Avatar
fwiw, my original TPS was replaced about 8000 miles ago @ 63k now I'm at 71k and I think mine is faulty as well, its intermittent, and the crank the throttle full open and release a half dozen times or so to sweep it trick seems to make it go away for a while
when I am making my own pace, it runs well, when I am stuck at the pace of traffic, is when it has issues, luckily, most of my riding is traffic free
I haven't had the time to check it myself and I know if I drop it at dealer, they will likely just wanna replace it
Janice, fwiw, I wish I had a fixed income, at least I would have an income
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 13 Old 10-15-2013, 05:13 AM
Austin44's Avatar
Heat kills electrics, from stators to TP sensors. The STPS is located high on a metal heat sink (throttle body). The TPS is mounted
low, very close to the heat source. At first, my TPS would only malfunction when the engine was hot from sustained riding.
Perhaps attaching a small, finned heat sink using thermal compound, like on a computer chip, would give a TPS longer life. Or
re-mount it using insulating gasket material. I thought of trying this but it's such a PIA taking everything off to get at it easily
and then get it adjusted. I decided new TPS and do it once since the original lasted 60K miles.
Austin
Austin44 is offline
post #7 of 13 Old 10-15-2013, 07:25 AM
om28's Avatar
This may seem like a dumb question to some of you, but what are the symptoms of a bad TPS?
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current - with 205K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #8 of 13 Old 10-15-2013, 07:32 AM
Stalling after long highway cruise. covers a typical situation.
post #9 of 13 Old 10-15-2013, 09:05 PM
Electrojake's Avatar
Anyone?
I was in the exact same frame of mind about a year or two ago with rare intermittent idling issues at about 35,000 miles.
No one could prove to me what the problem was (or wasn't).
I tested the TPS on the workbench according to the shop manual and it looked good.
The TPS is well buried under the tank.
Crash bars sure didn't help the situation either.
I believe it was Greywolf that convinced me to "just change it".
New TPS went in and all problems went away.
That was ten thousand miles ago and she still idles like a kitten.
To me that was proof positive.
-Ej-
A "Commuter" not an AdvTourer.
Currently Commuting On: 06 Harley XL1200C, DL1000k6, two old mopeds, and a pair of sneakers.
Electrojake is offline
post #10 of 13 Old 10-15-2013, 09:50 PM
Strange Dog's Avatar
...those problems are almost always a failure to idle properly after a long ride.
I encountered this problem at the end of last year (about 11 months ago). I still haven't fixed it, since the problem only arises during very long rides on very hot days, which for me are quite rare. I might get around to fixing it this xmas before it becomes a more serious problem.
[URL=http://www.fuelly.com/motorcycle/suzuki/dl650_v-strom/2011/strangedog/493573][IMG]http://badges.fuelly.com/images/sig-us/493573.png[/IMG][/URL]
[URL=http://www.fuelly.com/motorcycle/suzuki/dl650_v-strom/2006/strangedog/401455][IMG]http://badges.fuelly.com/images/sig-us/401455.png[/IMG][/URL]
Strange Dog is offline
