Madstad rattling - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 08-01-2007, 03:14 PM Thread Starter
randyo's Avatar
Madstad rattling
like the title says, my Madstad is making an annoying rattling
everything is tight, mounted in the tallest position, as soon as I get moving, I start hearing a faint tap tap tap tap, took me a while to isolate where it was coming from, but if I put my hand on the screen, the noise goes away
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 14 Old 08-01-2007, 03:34 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
Any noise I get from my screen seems to be coming from the black plastic cover strips that mount on the outside of the screen.
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #3 of 14 Old 08-01-2007, 03:40 PM
Cheff's Avatar
Mine got rattling to, and I tightened the guide screws a bit and it went away. It all looked tight, but one of them was just loose enough to rattle at speed.
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
post #4 of 14 Old 08-01-2007, 03:42 PM
I rock at logic
LucasD's Avatar
Ditto. Check the bottom nuts and bolts. There's fine line between keeping it adjustable and preventing them from rattling.
Now if I could only isolate the damn whistle I have!!!
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #5 of 14 Old 08-01-2007, 03:51 PM Thread Starter
randyo's Avatar
you mean the tiny ones with the nylock nuts that the screen slides on, I'll check that out, thanks
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #6 of 14 Old 08-01-2007, 03:58 PM
I rock at logic
LucasD's Avatar
Yup... those are the ones. Mine just recently loosened up and started
rattling.
2006 DL650
LucasD is offline
post #7 of 14 Old 08-01-2007, 04:19 PM
Banned
Lightbulb An inexpensive alternative
I don't mean this to knock the madstad, but that inexpensive fix I posted has held up very well. Never loosens up, and changes the wind trajectory to my satisfaction(6'5"). If you guys ever get tired of the madstad, you might want to try THIS.
I did have to hunt through a few hardware stores, (2 different ACE hardware stores had the parts.) but I am pleased with the results. I've had the bike up to 90mph since the original post and it seems stable. Never had to re-tighten once.
XLonDL650 is offline
post #8 of 14 Old 08-01-2007, 04:32 PM
Cheff's Avatar
Yep those are the ones...
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
post #9 of 14 Old 08-01-2007, 11:40 PM
16171
One thing I did when I installed my Madstad was to replace the washers on the SMALL bottom bolts to nylon washers. It allows them to be tightened tighter...but still be able to slide...no metal to metal contact either.
Just my two cents.
Matt
post #10 of 14 Old 08-02-2007, 06:51 AM
Scarlett Harlot's Avatar
My Madstad is a year old and maybe the model has changed some. Mine came with the locking bolts on the bottom and wingnut on the top. In April when I got my Givi the wingnut setup was not strong enough to hold the larger shield in place at hiway speeds. Mark sent me the the new knobs with the rubber washer and that was the solution for holding the shield in place. However, I still needed to use a wrench to Make adjustments so as to loosen the bottom bolts. I switched out the bottom bolts with the original wingnuts and added rubber washers and now the shield is rock solid and can be adjusted in seconds even while wearing gloves.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
