Is there a simple FM radio bluetooth solution for a Sena SMH10? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 10-03-2013, 11:26 AM Thread Starter
Captain Farkle's Avatar
Use the bike to commute to work, I have an Iphone, MP3s are good. Would like to have FM radio, something not expensive that is bluetooth that can pair to the iphone or Sena SMH10. It cant connect to the iphone directly because it goes into a waterproof case and has a cable to charge.
Been difficult to find, any suggestions for a simple FM bluetooth radio?
2012 650 Vstrom Black - Givi E52 Maxia Trunk,Givi Quick Release PLR3101 Racks, Givi E21 Silver Side Cases, Admore LED Brake and turn signals, SW Motech Crash Guards, SW Motech Center Stand, SW Motech Steel Rear Rack, SW Motech Bar Risers, OEM lower Cowling, OEM lower Seat customized by Triple K Upolstery, OEM Hand Guards, Eastern Beaver PC8, Givi Airflow Windscreen, Aprilla Mirrors, Dan Vesel Highway Pegs and Back Rest, Oxford Sport Heated Grips, FendaExtenda, Sena 10C, CREE LED Headlight Kit,10w Cree LED Work Lights,INNOV Wifi Bullet Cam
Captain Farkle is offline
post #2 of 25 Old 10-03-2013, 11:56 AM
Rogue Reaper's Avatar
I use my iPhone with "tune in radio" app. I keep my phone in a pocket or most often in my tank bag. I open the app and then shut off the screen, toss it in my bag and then turn on the Sena and hit the jog dial. It automatically feeds the tune in radio app.
The down fall, you cant surf stations unless you pull over and manipulate teh phone. The good, If you have siri you can just press the phone button and say "play music" and she will switch you from tune in to your onboard music.
hope that helps, thats my solution and with 1-1.25 hour commutes each way it has worked well.
'09 Wee, Orange. Uh, Er...White, No, Wait, ORANGE!
" I like my Motorcycle's Loud and my Firearms Quiet." -Me
Rogue Reaper is offline
post #3 of 25 Old 10-03-2013, 01:00 PM Thread Starter
My data plan is only 600megs wont cut the usage/cost.
post #4 of 25 Old 10-03-2013, 04:05 PM
My first post..I know you said not expensive, iPod nano has a radio and Bluetooth. $149.00
K8 DL650A
Tronto, Ontario
Lobsterbucket is offline
post #5 of 25 Old 10-03-2013, 05:46 PM
HotPockets's Avatar
Go buy a cheap walkman and use the aux cable....
'07 Yamaha Vstar 650 (sold)
'09 Honda CBR600RR (sold)
'12 WEEEEEEEstrom :biggrinjester:
'13 Yamaha FZ8
HotPockets is offline
post #6 of 25 Old 10-03-2013, 07:51 PM Thread Starter
Don't want to hook up another cable hence bluetooth the Nano is possible hope the earphones do not work as the antenna for FM
post #7 of 25 Old 10-03-2013, 08:11 PM
Just looked it up on the Apple. Unfortunately you are correct, the earphones are the antenna, the radio will not work unless the earphones are plugged in. Too bad.
K8 DL650A
Tronto, Ontario
post #8 of 25 Old 10-03-2013, 08:45 PM Thread Starter
Thanks for the idea though
post #9 of 25 Old 10-04-2013, 08:12 AM
Here's something I ran across this morning Bluetooth FM Transmitter and Music Playback. Don't know nothing about it and you would have to hook up a powerpoint for it.
Sabrekeeper is offline
post #10 of 25 Old 10-04-2013, 09:10 AM
HotPockets's Avatar
That wont work. That is a transmitter not a receiver. You put your radio on a certain station and connect your bluetooth so that you can hear calls through your car speakers.
'13 Yamaha FZ8
