Anyone have experience with speedo recalibrators? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 10-01-2013, 03:00 PM Thread Starter
So I spent yesterday installing new Anakee III's and a speedo recalibrator. Got done, bike won't start. Unhooked recalibrator, still no start.
Seems awful coincidental to have some sort of failure at the same time I hooked this thing up, anyone ever have this happen or heard of such a thing?
ReSS
ReSSurrected is offline
post #2 of 22 Old 10-01-2013, 03:03 PM
todd900ss's Avatar
Check the easy stuff first. Kill switch, maybe you bumped it? Bike in neutral, clutch in?
todd900ss is offline
post #3 of 22 Old 10-01-2013, 03:07 PM Thread Starter
All checked. Probably should have mentioned that the clock display now says "FI", and the red light in the center is blinking. All fuses checked for continuity also.
post #4 of 22 Old 10-01-2013, 03:11 PM
todd900ss's Avatar
There is a simple fix for this but I can't remember what it is, sorry. Use the google search on the home page and search FI light.
It's not in gear with the side stand down is it???
post #5 of 22 Old 10-01-2013, 04:41 PM
You have to check the FI code to pinpoint the problem. FAQ: Dealer Mode & FI Error Codes
post #6 of 22 Old 10-01-2013, 05:08 PM Thread Starter
Dammit, shoulda known someone smart would come along with a way to read the codes w/o the breakout harness, already dropped it off at the dealer....
post #7 of 22 Old 10-02-2013, 03:38 PM
bwringer's Avatar
Is the kill switch on...? DAMHIK.
Taking it to a shop seems rather drastic. The speedo calibrator wouldn't affect anything that would keep the bike from running, but it's perfectly possible to accidentally unplug or otherwise booger up something else along the way.
Also, more information is needed than "won't start". Will it crank? What happens?
Which calibrator did you install, and how, and where? Is it plugged in to the right place?
What bike? I'm assuming a Vee of some sort.
bwringer is offline
post #8 of 22 Old 10-02-2013, 06:39 PM Thread Starter
2009 V. Kill switch not on. Will crank, will not start. Instrument panel reads "FI" in clock field and red LED is blinking. I checked every single connector I could get my hands on. Removed calibrator, same result. Disconnected/reconnected battery, same result.
Installed this calibrator: Speedo Tuner Speedo Tuner - Street Motorcycle 2009 Suzuki V-Strom 1000 - Motorcycle Superstore at the speed sensor plug in behind the frame on the left side of the bike.
ReSS
post #9 of 22 Old 10-02-2013, 06:50 PM
The reason for the FI needs to be found. FAQ: Dealer Mode & FI Error Codes
post #10 of 22 Old 10-03-2013, 04:49 AM
Hmmm...bike started and ran fine before the tire swap and speedo calibrator? Betcha whatever the problem is finally diagnosed, you will end up smacking yourself for an oversight. One of those major "oopers" moments. Have you ever had one of these conundrums that keep you up at night only to awaken you from a deep sleep with the solution? I'd backtrack from the beginning and see if I accidentally pulled/yanked/snagged or otherwise damaged wiring while doing the work.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
