The Suzuki top box is too far forward...discuss... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 07-24-2007, 04:02 PM Thread Starter
Hi all,
on the latest 160-miler round South Devon, the wife complained that the standard Suzi top-box was pushing her too far forward and jutting into her lower back.
Without spending loads of hard-earned, how do I make her more comfortable? (GIVI is an obvious choice but involves some GBP 200+ which I am reluctant to part with...)
I've figured that, provided I forego the ability to quickly unlock and remove it, I can discard the quick-lock attachments and simply bolt the top-box to the standard rack, only some 3 inches further back.
Anyone tried this?
Be safe...
totfit is offline
post #2 of 13 Old 07-24-2007, 04:45 PM
MightyShep
adventure motostuff makes a rack that will let you move the box back further to accomodate a passenger.
post #3 of 13 Old 07-24-2007, 05:56 PM Thread Starter
It works.... just done it myself... tried and tested
Replying to my own post... a sure sign of madness.
Having given it some thought I decided to try my own suggestion. It works beautifully and the wife is now happy again. If you have the same problem, here's the fix:
- Remove top-box from rack.
- Loosen and remove 4 bolts holding rack to frame.
- Remove all top-box fittings from rack (2 front mushrooms and quick-lock rear.)
- Remove all 6 white rubber damping plugs.
- Mark new position of top-box approx 3 inches further back than standard.
- Carefully measure and mark your drilling points on top-box underside.
- Drill 8mm holes at front and 6mm holes at the back
- Reassemble using original bolts through top-box floor, through rack and into frame at front, using original nuts and bolts into quicklock fitting mounting holes at rear.
- Enjoy long miles with less complaining from rear passenger...
Safe Riding
totfit is offline
post #4 of 13 Old 07-24-2007, 06:44 PM
Heavy's Avatar
Rory, I don't know how the Suzuki box mounts but my wife had the same complaint as yours. I have a Givi V46 and Givi mount. I made up a couple of simple flat plate brackets that move the mounting plate back 2 inches to give her more room. I'll post a picture when photobucket is finished their maintenance shut-down.
DL1000K6
Heavy is offline
post #5 of 13 Old 07-25-2007, 05:03 PM
squeegee's Avatar
Can you post the link for the exact one you are describing?
Thanks ...Squeegee
I love ridin' my "FREAK"!:twisted:
DL650K7 Pearl Blue with OEM Centerstand, OEM top case/Luggage racks w/Nelson Rigg CL-850 Sb's
OEM Tank Cover, Back-Off Brake mod, Hot Grips, ProTaper KX high handlebars, 2 too many windscreens, DL1000 seat and Pat Walsh skid and guards ...why cant I stop ?!?!?!?!
squeegee is offline
post #6 of 13 Old 07-25-2007, 06:15 PM
I did the same thing. Moved the box back far enough to fit my camping stuff on the seat.
spongebob218 is offline
post #7 of 13 Old 07-25-2007, 06:19 PM
I have a GIVI top bag and while my wife hasnt started yet, I see it in my future.... Looking forward to pics from heavy...
Thank God for pics, they make things for people such as myself actually do somethings on his own.
denysp is offline
post #8 of 13 Old 07-25-2007, 06:59 PM
Heavy's Avatar
oops...forgot all about it...
DL1000K6
Heavy is offline
post #9 of 13 Old 08-01-2007, 01:26 PM
V-Tom's Avatar
Heavy:
Where those on your bike this weekend? I didn't notice any difference to look at but if they move the case back that much it would be wonderful!
How long were the bars?
Thanks,
Tom
SMIDSY detailed report.
V-Tom is online now
post #10 of 13 Old 08-01-2007, 07:01 PM
I did what Heavy did and fabricated my own bracket to move the thing back an inch and a half. I did it slightly different way in that I created two plates that I attached on top of the mount plates. Then attached the plastic rack to the new plates.
torqueman is offline
