Method to straighten bars? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 09-29-2013, 09:55 PM Thread Starter
I had some new springs installed and my bars are just ever so slightly not straight now. I fiddled with the riser set up but I am sure the fork tubes are not perfectly straight in the triples.
So what is the best way to get them everything lined up?
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
stephenmarklay is offline
post #2 of 13 Old 09-29-2013, 09:56 PM
Simple....replace the steel flimsy pieces of crap with an aluminum bar instead.
post #3 of 13 Old 09-30-2013, 09:01 AM Thread Starter
I have Pro Taper bars on it. I don't think the bars are bent but rather the triples are not perfectly aligned?
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
post #4 of 13 Old 09-30-2013, 10:19 AM
If you had loosened off the pinch bolts when you where installing new springs or took the forks off its probable that the upper & lower tree aren't lined up. You should be able to visually see this if you look down from above.
A couple of things you can do.
You may need a helper. Loosen the pinch bolts on the top tree/forks and gently turn the handlebars until the upper & lower tree are lined up. Then retighten the pinch bolts.
Also if you had a fork brace on the bike ( take it off ) and if not, loosen the fender bolts. Make sure the fork tube pinch bolts are tight. Apply the front brake and pump the front end of the bike up and down a few times, then reinstall the fork brace or retighten the fender bolts. This will help line the components of the fork tubes with each other.
Hope this solves your issue.
cycleman is offline
post #5 of 13 Old 09-30-2013, 10:44 AM Thread Starter
Ok guys thanks. I will do this today. I just did not want to end up with them more crooked.
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
post #6 of 13 Old 09-30-2013, 11:17 AM Thread Starter
The tech that installed the springs took the fork tubes out so I am pretty sure that the triple clamps are what is off. I don't think he had to touch the top nut.
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
post #7 of 13 Old 09-30-2013, 11:43 AM
hunt1moore's Avatar
Loosen only the bolts on the bottom triple tree and pinch bolts on axle. Push up and down on forks to help re-align. If nothing has been bent or damaged then it should be easily re-aligned. Torque bolts back to spec.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #8 of 13 Old 09-30-2013, 11:52 AM Thread Starter
Well a few different options I guess :mrgreen:
I did not see the last post before I went out. I loosened the two top bolts (I did not see your post hunt1moore) and put the tire next to a stud in the garage and applied a bit of pressure to the bars and now they are perfect. After the fact I undid the axle pinch bolt and brace to make sure that was not binding.
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
post #9 of 13 Old 09-30-2013, 03:00 PM
hunt1moore's Avatar
No problem. Upper or lower just not both.
Loosening the axle pinch bolts help with making the forks parallel.
post #10 of 13 Old 10-01-2013, 06:25 AM
Watch the video ForkTru - Fork Alignment Tool | Motion Pro pretty cool tool you can do the same thing with a piece of flat glass but we like tools.
BornAgain is offline
