Fairings are off and gas tank is too, I wonder stromtroopers what should I do? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 09-23-2013, 04:40 PM Thread Starter
E.Ness's Avatar
My front fairing off, side panels too
the tank is removed without too much ado.
air filter is cleaned and letting it dry.
when it is ready oil I'll apply
the fastners are numbered with tape that is masking
so that putting them back "should not" be too tasking.
Now that the insides of my wee are exposed.
Some wiring corrections and upgrades proposed.
"oh no" said the troopers "your circuits will blow!
The gps wired to the headlight must go"
"H4 dual headlight relay kit we advise.
heavy duty disconnect option is wise
PC-8 panel or 3 circuit solution,
have all your accessories and no retribution"
Is this complete, did I leave anything out?
if you think of something please give me a shout!
Because a thing seems difficult for you, do not think it impossible for anyone to accomplish.
Marcus Aurelius
E.Ness is offline
post #2 of 20 Old 09-23-2013, 05:12 PM
He's a poet
and didn't know it:beatnik:
BornAgain is offline
post #3 of 20 Old 09-23-2013, 07:05 PM
Haiku is not precise.
He didn't mention rattle canning the surface for a more unique appearance.
post #4 of 20 Old 09-23-2013, 08:36 PM Thread Starter
E.Ness's Avatar
Haiku
Too naked wee sleeps
Eastern Beaver rising sun
Shoei awaiting
Marcus Aurelius
E.Ness is offline
post #5 of 20 Old 09-23-2013, 09:35 PM
568v8's Avatar
way too funny
my Vees just the same
alone in my shop
with just me to blame
the oil change is done
of course a filter as well
it's all sort of fun
K&N filter still damp
it's get's oiled when it's dry
either by sun or a lamp
sometime I say F....
hope that tank will fit back
those plastic rivets do suck
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #6 of 20 Old 09-23-2013, 10:03 PM
Are you going to check valve clearance at this time?
arty-up is offline
post #7 of 20 Old 09-23-2013, 10:26 PM
EVstrom's Avatar
With all of the wonderful wording and rhyme
All you come up with is "check valve clearance this time?"
Your lack of alliteration does not match with those
Who offer advice with creativity through prose!
Sent from Motorcycle.com App
Master of the obvious...
Ol' Bug Brain of the Sons of Practicality MC
2012 DL650AL2
EVstrom is offline
post #8 of 20 Old 09-23-2013, 10:48 PM
Clone's Avatar
Plugs and valves, since it is apart anyway.
Not to hi-jack, but does a Wee have enough juice to run high and low beams at the same time?
Clone is offline
post #9 of 20 Old 09-23-2013, 10:49 PM
Some times, I just can't help myself.
arty-up is offline
post #10 of 20 Old 09-23-2013, 11:26 PM Thread Starter
E.Ness's Avatar
valve clearance
it very true
valve clearance is due
a good point you bring to my mind.
yet valve clearance or clutch
engine work and such
best to an expert assigned.
I can farkle with flair
in tires put air
alas not so mechanically inclined .
Marcus Aurelius
E.Ness is offline
