Emergency flasher button - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-17-2013, 07:37 AM Thread Starter
ron47's Avatar
The flasher button on my 2007 Wee will not lock in. If I hold it, the flashers work so it is making contact. Tried opening the clam shell and lubricating/cleaning with WD40 with no improvement. Common failure? Solution a complete housing replacement?
Thanks
RonNBama
ron47 is offline
post #2 of 11 Old 09-17-2013, 08:35 AM
The usual problem is the two screws that hold the housing together getting switched. The longer one should be in front so it doesn't foul the switch. Even if they were only swapped once, the switch housing could have been distorted.
post #3 of 11 Old 09-17-2013, 08:37 AM Thread Starter
ron47's Avatar
Thanks Grey, I'll try relieving the stressed parts and see if I get any change. I do like having that emergency flasher option so a new housing may be in my future.
RonNBama
ron47 is offline
post #4 of 11 Old 09-17-2013, 08:50 AM
p38arover's Avatar
Hmm, I'll check that as mine is a bit dicky, too. Thanks, GW.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #5 of 11 Old 09-17-2013, 12:48 PM
I had that problem with my '07. I found that the screws weren't reversed, but the short one was still making contact with the button, so I shortened it, & put a little di-electric in there.
As I bought the bike used, I can't say if that screw was where it belonged or not. But it was very obvious which screw goes where.
2007 DL 650 with assorted upgrades
Solo is offline
post #6 of 11 Old 09-17-2013, 10:37 PM Thread Starter
ron47's Avatar
So the clam shell screw was stopping the button from latching in the flash position? Hmmmmmmm.
RonNBama
ron47 is offline
post #7 of 11 Old 09-18-2013, 06:58 AM
MeefZah's Avatar
It's a common problem with them, my '07 came new from the dealer like that. Fix was to swap the screws as has been suggested, although by now that switch may have been buggered up internally by 6 years worth of attempting to engage it.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #8 of 11 Old 09-18-2013, 12:56 PM
Sorry, reading is hard for me
I see now we are talking about two different problems. My problem was the button was frozen & would not depress.
Swapping the screws wouldn't work for me because the other one was longer, so I shortened the problem screw.
Solo is offline
post #9 of 11 Old 09-18-2013, 04:57 PM
p38arover's Avatar
I backed off the screw under the button and it seems to have fixed it.
However, I noticed my emergency flashers, unlike my cars, only work with the ignition on. I shall have to find the owner's handbook to check if that is correct.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
post #10 of 11 Old 09-18-2013, 05:06 PM
That's normal.
