Foamy Oil - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 09-16-2013, 10:45 AM Thread Starter
Foamy Oil
Lately when I come back from a ride and look in my oil sight glass I notice my oil is fomey, full of bubbles.
Happens all the time now.. Bike is a 05 with 46,000 miles.
Could it be water or gas in the oil.
The bike does seem to be using a little oil now which it never did before. About 1/2 quart in about 1,500-2,000 miles.
Ring job??? I hope not.
Thanks
albmw1100rtp is offline
post #2 of 16 Old 09-16-2013, 10:51 AM
Ex- moderator
Water in oil causes it to look like a malted milkshake, gasoline in oil is burned off quite quickly actually..
Did you know that WWII russian pilots used to dump some gasoline in the crankcase oil of their airplanes in order to thin the oil enough that the engine could be turned over to start?... Once started the gas would evaporate, returning the oil to its original thickness..Dont try this at home kids - it only works at -50..
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #3 of 16 Old 09-16-2013, 10:59 AM Thread Starter
If it is water how the heck did it get into the oil system?
post #4 of 16 Old 09-16-2013, 11:06 AM
Craig Jackman's Avatar
Leaking head gasket? Leaking water pump seal?
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #5 of 16 Old 09-16-2013, 11:15 AM
Coolant in the oil causes a buildup often referred to as mayonnaise. If there are only bubbles without a change in consistency or color of the oil, the anti foaming agents in the oil may be worn out. How much time and mileage is on the oil in question?
post #6 of 16 Old 09-16-2013, 11:54 AM
MeefZah's Avatar
Or it may be overfilled.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #7 of 16 Old 09-16-2013, 12:06 PM
two_wheeled's Avatar
Take a picture so we can see what kind of bubbles you're talking about.
-Steve in Phx.
Current: 2011 DL650A, Honda XR650L
Lost Loves: 2003 Honda ST1300A, Kawasaki Concours ZG1000, Honda Shadow VT500C, Honda Nighthawk CB700SC, Kawasaki KLR600, Yamaha TT500, Honda XR75
two_wheeled is offline
post #8 of 16 Old 09-16-2013, 12:15 PM
randyo's Avatar
Thanks
If you actually are consuming oil, its more likely worn valve seals & guides than it is rings
the most you should see thru the sight glass with the engine running is an occasional bubble or splash
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 16 Old 09-16-2013, 01:41 PM
Change to good oil
richw is offline
post #10 of 16 Old 09-16-2013, 01:54 PM
Originally Posted by richw View Post
Change to good oil
Oh boy.....
1997 Honda Valkyrie 1500 custom ďDoloresĒ
