Bestem Top cast wobble - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 09-09-2013, 02:47 PM Thread Starter
dravnx's Avatar
I have a Bestem T Box 929 top case and the mounting doesn't seem very secure. I put some 1/4" foam tape between the mount and the box to take up some of the slack and it worked for a while but over time the foam has compressed the the wobble is back. Anyone come up with a fix?
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #2 of 9 Old 09-09-2013, 06:30 PM
rodr's Avatar
I use a mouse pad; cut it in half to make 2 layers.
Rod
Orange Wee Club member #18
DL650K9 with Murphs center stand, SW Motech Rally crash bars, Madstad bracket, Dan Vesel luggage guard and tube,
Bestem top box, Nelson Rigg CL-850 saddle bags, Rapid Transit Abrams tank bag, Beadrider, SH-775 R/R
rodr is offline
post #3 of 9 Old 09-09-2013, 06:36 PM
I used rubber grommets that they make after you put a hole into a firewall of a vehicle to run wires. Make sure it's the correct size, put a little soap on it and slide it over the two font tabs. Just make sure when you put the top box on that the grommets are between the top box and mounting plate.
Been working for me for the last 4 years...:beatnik:
[SIGPIC][/SIGPIC]"Free Men Will Never Consent To Give Up The Means Of Defending Their Liberties"
Buzzzer is offline
post #4 of 9 Old 09-09-2013, 06:49 PM
What he said.
06 V-Strom DL650
John V Strom, Jr. is offline
post #5 of 9 Old 09-09-2013, 06:57 PM
Kelly2012's Avatar
I am planning on tapping some fasteners through the box, and into the mounting plate. My wife uses it as a backrest and I never take the box off anyway.
Kelly2012 is offline
post #6 of 9 Old 09-09-2013, 08:27 PM
I did the same.
robrm250 is offline
post #7 of 9 Old 09-09-2013, 09:33 PM
Dogknot's Avatar
I put some self adhesive rubber bumpers from the hardware store. $2.00 fix. Then, while showing my brother how stable it was, & how easy it can be removed. I drove off without locking box in place. turned the corner at 30. The box went straight. It held up good aside for a scratch.
Dogknot is offline
post #8 of 9 Old 09-09-2013, 10:02 PM
jokermtb's Avatar
I'm gonna wrap some rubbery stuff around the mount plate pins that stick up, to take up the slack where the top case fits into the pins.
I do the mouse pad thing, but the loose fit pins allow the topcase to wiggle fore/aft and side to side. Mouse pad only stops the up and down!
jokermtb is offline
post #9 of 9 Old 09-10-2013, 09:13 AM
Rick505's Avatar
I found some heater hose and picked up a foot of it from the local hardware store and cut a piece that fit over the existing rubber mounts. I seem to recall it had 1/2" ID and I cut the length to take up the excess slack when mounted. Seemed to do the trick for me since my self adhesive rubber bumpers and stuff eventually either moved or fell off. I also used a thick mouse pad initially.
Rick505 is offline
