!*&$^#@%$ Suzuki hardware!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 37 Old 09-08-2013, 10:07 PM Thread Starter
teevee's Avatar
Thumbs down !*&$^#@%$ Suzuki hardware!!!
stripped the head of yet another POS suzuki bolt yesterday. seriously, these things are made of the shittiest metal on the planet. it's a friggin wonder these damn bikes don't fall the f%$&* apart on their own.
'08 DR650, '07 DL1000
teevee is online now
post #2 of 37 Old 09-08-2013, 10:19 PM
wingnut11's Avatar
Bummer, it's why the guys at ace hardware recognize me so well.
wingnut11 is offline
post #3 of 37 Old 09-08-2013, 10:49 PM
One of the plastic fairing bolts by chance? If that is the case, add some anti-seize and do not tighten so much, the bolts for the plastic bits should just be snugged down.
post #4 of 37 Old 09-08-2013, 10:55 PM
LordSmoke's Avatar
I have by now replaced nearly every bolt I've had call to remove with SS...Ace is the place...
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #5 of 37 Old 09-08-2013, 11:23 PM
It might be worse where you are in FL with the salt in the air. You may benefit from getting some Corrosion Block spray and spraying the bike down. I just did this on the bike I will be using this fall and winter to keep the corrosion at bay.
That will penetrate in the hardware stopping corrosion and also act a bit like a penetrating oil.
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
stephenmarklay is offline
post #6 of 37 Old 09-09-2013, 12:53 AM
randyo's Avatar
may I ask what bolt and what tool you used ?
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #7 of 37 Old 09-09-2013, 01:26 AM
Suzuki makes their bolts out the finest cheese available.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #8 of 37 Old 09-09-2013, 01:29 AM
Be careful where you use stainless steel in place of OEM carbon steel hardware. In general, hardware-store type "SS" hardware has less strength than carbon steel. Plus you may end up with thread galling making them harder to get out when you have to.
Stainless Bolts--Usually very weak! | eBay
Stainless and Carbon Steel [Archive] - Shop Floor Talk
Fastener Material Selection
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
post #9 of 37 Old 09-09-2013, 06:48 AM
Bucket's Avatar
I feel your pain, but I had to laugh...I see this post on every motorcycle forum I visit...Yamaha, Kawi, Honda....I don't know that one is better than the other.
Most can be replaces pretty easily, but other bolts are a little tougher to find...if you want the same style.
2013 White Glee...farkles added daily.
Bucket is offline
post #10 of 37 Old 09-09-2013, 07:17 AM
I assume you're not using a torque wrench - I have never broken a fastener torqued to the correct spec. You can keep blaming the cheap fasteners, but if you keep over-torquing them, they'll keep breaking. At some point, it's your heavy hand to blame, not the fasteners.
If you ARE using torque wrenches, check their calibration.
"too loose" = tighten; "too tight" = broken.
phoenixsteve is offline
