Wobble at 35 mph with no hands. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 32 Old 07-07-2007, 10:28 AM Thread Starter
jmz
jmz's Avatar
If I take my hands off the bars when decelerating my steering wobbles at around 35 mph . Is this normal ? My bike rides goos other than that. Should I be worried about it?
2012 Super Tenere
2014 KTM 500 XCW plated
1993 CT70
jmz is online now
post #2 of 32 Old 07-07-2007, 10:33 AM
One, the stock trailwing front tire gets a strange wear pattern, so it wabbles a bit. Once you get ride of the trail wing front, you won't have that problem anymore. BUT, Check all the nuts and bolts anyway. When was the last time you retorqued the head bearing? Not that that is causing it, but it is an item that seems to always come up.
There are other threads on this subject also.
flyinggreek84 is offline
post #3 of 32 Old 07-07-2007, 09:00 PM
jacob's Avatar
Mine also has this quirk after the ft tire gets wore down aprox 60%.It only does it when slowing with hands off bars.It has done this with many different ft tires using differing air press.I was told by a custom bike builder that this is common with bikes raked like ours.I just figured it was my bikes way of telling me to get my hands back on the bars.
02-blue DL1000/94k
jacob is offline
post #4 of 32 Old 07-07-2007, 11:50 PM
All bikes will do the hands off the bars decel wobble.
The speed at which it occurs will vary according to steering geometry, tires, suspension etc.
Try varing the tire pressure and make sure all suspension components are within spec. Try different tires when the current ones wear out.
Mountaintime05 is offline
post #5 of 32 Old 07-09-2007, 11:41 AM
MonkeyGrass's Avatar
Send a message via AIM to MonkeyGrass Send a message via MSN to MonkeyGrass
Heh. Don't try the Tourances if you are worried about the wobble. They make it worse.
[SIGPIC][/SIGPIC][I][SIZE=1][SIZE=3][SIZE=3][B]
V-Strom - embarrassing squids since 2002.[/B][/SIZE][/SIZE]
[/SIZE][/I][FONT=Georgia]DL1000K2 #938
[SIZE=1][COLOR=Navy][B][SIZE=2]Blue, of course!!
[/SIZE][/B][/COLOR][/SIZE][/FONT][FONT=Book Antiqua][SIZE=2][I][B]
R.I.P Jason. You will be missed.[/B][/I][/SIZE][/FONT]
MonkeyGrass is offline
post #6 of 32 Old 07-09-2007, 12:35 PM
darin bell's Avatar
Mine wobbles also. It did it with the trailwings and it does it with the pilot roads.
Darin
___________________________
'05 BMW R1200RT
'03 Honda XR400 (Dual Sported)
'71 AJS 370 Stormer
darin bell is offline
post #7 of 32 Old 07-09-2007, 01:46 PM
V-Tom's Avatar
I had a thread a few months ago asking basically the same question. It seemed to be a fairly normal occurance with many other riders experiencing the same thing. The wobble takes almost no efrot to stop, but without hands on the bar it gets worse. I can tell you that a fork brace does *not* cure this, although I think it made it slightly better.
I think the only answer, as has been mentionend previously, is not to take the hands off the bars.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #8 of 32 Old 07-09-2007, 03:50 PM
Talking
Mine wobbled with the trailwing front, but with the Conti Road Attack, no wobble, I can set my "po-boy throttle lock" and sit back with my arms folded across my chest and sail down the hi-way!!! Smooth....
05 DL1000
74 Yamaha 650
70 Honda CL450
67 Sears 106SS
01 Kawasaki KLR250
Gary is offline
post #9 of 32 Old 07-09-2007, 04:06 PM
darin bell's Avatar
Mine doesn't wobble on the road, only when slowing down around 35 mph.
Darin
'05 BMW R1200RT
'71 AJS 370 Stormer
post #10 of 32 Old 07-09-2007, 05:21 PM
Mine does this as well. 200 miles on bike.
foxer is offline
