Brake light(s) not working - need advice - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-02-2013, 11:34 AM Thread Starter
Prime's Avatar
My rear brake light isn't working when either the hand or foot lever is applied. I thought I had a burned out bulb so I figured this was an easy fix. Of course I noticed 2 bulbs in the rear housing that act as both running lights and brake lights. Hmmm.... what is the chance that BOTH brake lights are burned out at relatively the same time? I checked the fuse and a few other things. Everything seems proper.
I took one of the bulbs to my local auto store and the fella behind the counter checked the bulb and both filaments light up independently. So, it looks like I have an issue with my brake light wiring, power, connection, etc... ???? I dunno... When I got back home and put the bulb back on the bike I noticed that both filaments are on at the same time. They both stay on and when I apply the hand/foot brake lever but neither of them gets brighter.
It might be worthy to mention that I installed a peg lowering kit from Rick the other day. Don't know if that has anything to do with the brake lights going kaputs or not. Need help.
"If everyone demanded peace instead of another television set, then there'd be peace" - John Lennon
"Every gun that is made, every warship launched, every rocket fired, signifies in the final sense, a theft,
from those who hunger and are not fed, from those who are cold and not clothed" - Dwight D. Eisenhower
Prime is offline
post #2 of 11 Old 09-02-2013, 11:43 AM
jokermtb's Avatar
I'm currently struggling with my front brake lever taillight switch not doing it's thing.......I freekin' hate electrical weirdnesses.....
jokermtb is offline
post #3 of 11 Old 09-02-2013, 12:09 PM
Stop light not working
Since you just installed a peg lowering kit, I think I would start down in that area, sure you got the stop switch adjusted correctly? I understand thats part of the procedure for the lowering kit..Good luck....Pete
Pbarn is offline
post #4 of 11 Old 09-02-2013, 12:21 PM
Do pull up on the spring to the rear brake light switch to test it. When people report no brake lights from either brake lever, it's usually a matter of the brake light being stuck on, almost always at the rear brake light switch.
post #5 of 11 Old 09-02-2013, 12:22 PM Thread Starter
Prime's Avatar
Pbarn, I just got done fixing my problem. It was indeed the peg lowering kit that I recently installed. The spring wire had too much tension on it (from being lowered a full inch) and this caused the brake light to be "on" all the time. When I hit the brake lever, nothing happened, because it was already activated!!! Been that way for a couple of days now
Mods: please punt this thread to the "Maintenance for Dummies" section or start a "Thread of Shame".
Happy Labor Day - Be safe!
Prime is offline
post #6 of 11 Old 09-02-2013, 12:24 PM Thread Starter
Prime's Avatar
Pat, you nailed it. It was "ON" the whole time, and not off or burned out. Fixed and back to normal now. Relatively speaking...
Prime is offline
post #7 of 11 Old 09-07-2013, 01:11 AM
cb4017's Avatar
Don't feel bad. You're not the only one who's done this. Ask me how I know.. :mrgreen:
Cliff
FPD Ret., USN Ret.,
Never Underestimate the power of stupid people in large groups.
cb4017 is offline
post #8 of 11 Old 09-07-2013, 08:42 AM
When you see hoof prints in Kansas don't look for Camels
richw is offline
post #9 of 11 Old 05-08-2014, 02:30 PM
Mauricio78 is offline
post #10 of 11 Old 05-08-2014, 02:31 PM
Do you have any picture?
thx
