Tire patch kits - plugs or strings ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-03-2007, 02:17 PM Thread Starter
rhbell's Avatar
Did a few searches to try to find what folks generally carry in terms of tire repair kits - seems there's a mix of sting type patches and plugs . Interested in members thoughts? - any kits that perhaps carry both. Also, any sources for such kits in Canada?
Thanks and safe riding
Bob
Necessity may be the mother of invention, but desperation is it's father........... (Bell)
'06 DL650
rhbell is offline
post #2 of 11 Old 07-03-2007, 11:53 PM
Send a message via Yahoo to Monterey10
Plugs
I've had good luck with the "Stop and Go" tire plugger. I have the gun that forces the plug into the tire. Two issues to consider. 1) The hole in the tire needs to be rounded out to the correct size for either the plug or string. 2) I had a nail go through the bottom of the tire and cut the interior cords in the side wall. This was not visible from the outside. So, I view a plug as a temporary fix, until a new tire can be found.
This said, I have a friend that ran a plugged tire for 15K miles w/o problems.
Monterey10 is offline
post #3 of 11 Old 07-04-2007, 12:27 AM
I carry the sticky string that doesn't require cement. Any time I've looked at a tire repair kit containing cement in any of my vehicles, the cement was, at best, hardened and, at worst, migrated before hardening. Hopefully, the Ride-On compound in my tires will repel puncturing items like wearing rain gear on a hot day keeps the rider in the one place in the area where it doesn't rain. That's the way it's been for me for many years.
post #4 of 11 Old 07-04-2007, 09:18 AM Thread Starter
rhbell's Avatar
Good input - thanks. I may dop by our local Cda Tire and maybe pick up a kit - am assuming at this point that a kit listed as for radial tires )car) will work for radials (bike) as well.
Thanks and safe riding,
Bob
'06 DL650
rhbell is offline
post #5 of 11 Old 07-04-2007, 11:06 AM
I had to fix a flat rear tire at the end of May. Used the sticky string type and it has held perfectly. Note that the "kit" only included the strings and insertion tool, not the required reamer tool. You will need the reamer to make small holes (staples, small nails, etc) large enough to get the string/tool inserted. Couple that with a 12V air compressor and you should be good to go. The air compressor also lets you lower tire pressure for off-pavement adventure, then get back up to street pressures for the ride home.
garry is offline
post #6 of 11 Old 07-04-2007, 12:12 PM
Check out motopumps.com for a kit that includes the air compressor, repair kit, and some other goodies that have been useful. The whole kit fits under the seat and is a good price. Owner Rob is also a Strom rider that may knock off a few bucks for mentioning Stromtrooper. The air compressor has been great and you can get it so that it connects directly to the battery (so you don't have to have a power outlet). I use it whenever I need to fill up the tires.
Drew
07 DL650
dlfunk is offline
post #7 of 11 Old 07-04-2007, 05:59 PM
I have the motopumps.com kit and think it's pretty cool for the money, but mine did NOT come with a reamer. Go figure. First step in using the supplied string kit is "ream the hole out with the reamer". What reamer? Mine did come with a non-functional pressure gauge though. Lesson Learned: check out all the stuff in the kit before expecting to use it on the road. Don't get a roadside surprise like I did (dead air pressure gauge and no reamer).
garry is offline
post #8 of 11 Old 07-06-2007, 03:07 AM
Send a message via Skype™ to defusingdanger
Plug
I have used the plug type fix, which was holding quite well (both of them, actually). But then I did something silly, like say lowered my tire pressure, and they fell out. I gather that they are supposed to somehow bond with the tire's rubber, but that did now seem to happen in my case, don't really know why. Being easy to use, I just put a new one back in and had a far more interesting time ridding back out on dirt then on the way in.
Cheers,
Christian J.S.
DL1000 '06 *Green*
"All animals are equal, but some animals are more equal than others."
(such as the '1000)
defusingdanger is offline
post #9 of 11 Old 07-06-2007, 03:51 AM
strom lurker's Avatar
I also have the plug type. No issues. I think it's a talisman for not getting flat tires. Since I bought it, no flats! Also, as mentioned above, a small compressor is key. I've used it several times for riding buddies. More than paid for itself.
Current Stable:
1971 Honda CB500 Cafe Racer
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
1993 Yamaha GTS-1000 x3
2000 Hayabusa
2003 V-strom
strom lurker is offline
post #10 of 11 Old 07-06-2007, 10:33 AM Thread Starter
rhbell's Avatar
Thanks - appreciate the advice. I checked out motopumps but since I already have a mini compressor on board I wont likely go that route. Can I safely assume that a plug/string kit for a radial tired car will work on a radial bike tire as well.?
In my mind they should but thought I'd ask.
Thanks and safe riding.
Bob
'06 DL650
rhbell is offline
