Suzuki OEM Luggage mounts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-03-2007, 08:26 AM Thread Starter
squeegee's Avatar
Hey Stromies,
Has anyone installed saddlebag mounts WITHOUT the top case mount? I bought the OEM side case mounts for soft luggage and possible future upgrade to the Suzuki hard cases, then read the fine print and discovered you cant mount the side mounts without the top. I dont want to spend over $200 just to mount soft luggage. I got them yesterday and I havent opened them yet, but i wanted to know if maybe with some different hardware or minor mods i could fit them to the bike without the top case? Does anyone know how feasible this is? Thanks in advance ... squeegee
I love ridin' my "FREAK"!:twisted:
DL650K7 Pearl Blue with OEM Centerstand, OEM top case/Luggage racks w/Nelson Rigg CL-850 Sb's
OEM Tank Cover, Back-Off Brake mod, Hot Grips, ProTaper KX high handlebars, 2 too many windscreens, DL1000 seat and Pat Walsh skid and guards ...why cant I stop ?!?!?!?!
squeegee is offline
post #2 of 6 Old 07-03-2007, 02:35 PM
msi1259's Avatar
Originally Posted by squeegee View Post
Hey Stromies,
Has anyone installed saddlebag mounts WITHOUT the top case mount? <nip> squeegee
Two of the three mounting points for the side case rack on my DL1000K5 are on the top case rack (see attached picture). Might be a lot of work to make it work without the top rack....
DL1000K5
msi1259 is offline
post #3 of 6 Old 07-03-2007, 02:52 PM
That is correct. The OEM top case rack can be mounted solo, but the side cases are dependant on the rop case rack.
I ran into this when I bought my bike. It had factory side cases installed and a factory top case. The top case itself was on a massive back order so I was looking for other options. Was going to buy the Givi top case, but found out I couldn't change the top case mount without loosing the side cases.
Ended up swapping the whole system out for Givi. Irony is that the Zuk top case arrived the same day the Givi did, so I know have two complete sets, factory and Givi.:???:
emsdaddy is offline
post #4 of 6 Old 07-03-2007, 03:01 PM Thread Starter
squeegee's Avatar
Ok thanks for the info, i am not even going to bother opening them and I will just have to ship them back. Thats ok I wanted to buy something from Dan Vesel anyways! Thanks for the input ... squeegee
squeegee is offline
post #5 of 6 Old 07-03-2007, 09:22 PM
silverstrom's Avatar
Hey Stromies,
In case you change your mind, I just bought the Suzuki top case and mount and I only paid $122 CDN for the top mount. Cheap considering it replaces the entire rear rack and looks great.
SS
silverstrom is offline
post #6 of 6 Old 07-04-2007, 03:41 PM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
I'm running the reverse: OEM topcase with Givi sidecases and racks.
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
