DIY storage tube write-up, with locking interface! Vstrom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-03-2007, 01:12 AM Thread Starter
zed88's Avatar
Send a message via AIM to zed88
Materials needed:
1 Stanely double hinge clasp lock 1 2 Section of 4 pipe (either normal, or thinwall)
1 Waterproof lock
1 4 End cap for drinking water (you can also use a flat end)
1 4 female end
1 4 screw on Male cap
1 PVC Primer
1 PVC Cement
1 can of Krylon black fusion
1 caulk or other waterproofing agent
Tools
Hacksaw
File
Screwgun with 1/8th drill bit
Rag
Sorry for the poor pictures, I dont have a digital camera.
Go ahead and cut the pipe to a desired length (I used 17) with a hacksaw, and then use a file to remove the burred edges. Wipe all dust off with water. After you have done that sandpaper the edges to get it roughed up a bit and apply PVC primer to both pieces. Then apply Cement to both the inside, and outside of both pipes. Twist the end cap on with a turn and let dry for 5-15 minutes.
Repeat this for securing the other end (male/female end).
Now attach the latch as shown. You will need to drill pilot holes with a 1/8th drill. Make sure to apply some caulk to the back of the screws to maintain a waterproof seal when done. The latch also doubles as a lever if the lid should the lid get stuck. Make sure you have the lid screwed down all the way before installing the hinge. Otherwise it wont line up!
After screwing it down and caulking, let it dry for awhile. If you feel like it, you can cut off the screws before you caulk over them. I didnt mind the little bumps so I left them in.
Now you can paint it with your desired color. I use krylon fusion because its supposed to bond to plastic good. After it has finished mount it on the bike. Dont forget to loctite your screws so they dont vibrate off. I used some steel L brackets, rubber offsets, and hose clamps. Im partial to how JBH painted his:
http://www.twtex.com/forums/showpost...&postcount=352
You can also run a bungee around the lock to keep it from vibrating, and banging against things.
Congrats, you now have a secure, durable, waterproof, connection that distributes weight low on the bike, and is an efficient use of space. Its tough enough to get ejected from the bike, and keep all your tools intact. If you are going off-road you can throw your phone and wallet in it. Best of all it was less than $40!
Eric :jkam
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #2 of 8 Old 07-03-2007, 10:13 AM
Got any photos of how you mounted it to your bike? I am planning on making something similar this week and have been trying to figure out how to mount it to the bike. I have considered mounting it to the givi rack with some pipe clamps and angle iron, but haven't decided for sure yet.
04 blue wee
sbdep is offline
post #3 of 8 Old 07-03-2007, 03:23 PM
Darn! I'd love one of those, but i have an exhaust pipe in the way :wink:
darkjedip is offline
post #4 of 8 Old 07-03-2007, 03:53 PM
Very cool! I might have to make one of these. I'm missing an exhaust on one side :mrgreen:
GrayStrom is offline
post #5 of 8 Old 07-04-2007, 12:24 AM
Night_Wolf's Avatar
Am interested in how it mounts also as I just made two tonight (one is for the fella who purchased my 05 Wee)
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #6 of 8 Old 07-04-2007, 03:01 AM Thread Starter
zed88's Avatar
I finished painting it tonight. After much head scratching (mounting it is difficult), I figured I was making it too complicated and looked around the garage to see what I had laying around. Lo and behold I found some nice U Bolts, washers and lock nuts lying around. Drill a few holes, and it pops right on. The pictures show the front U Bolt, and then on the rear of the can I used a pipe clamp, with rubber insulator.
Has anyone ever had the pipe smack the chain guard if you really hit a bump? I tried to retain maximum clearance but I still wonder.
Painted:
Bike with my new luggage:
Looking down from the back:
U-bolt:
No pics of the pipe clamp. Sorry
zed88 is offline
post #7 of 8 Old 07-04-2007, 08:15 AM
how much to 08844?:mrgreen:
absdl650 is offline
post #8 of 8 Old 07-04-2007, 09:15 AM
Mounting a pipe is just one more reason to get SW-Motech quick lock racks. It's much easier to make mounting brackets for the big flat parts than the tubular Givis.
