Lock-tite - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-01-2007, 02:59 PM Thread Starter
Lock-tite
After spending an hour looking for a pipe to use for a cheater bar, and twenty minutes installing the lowering links and raising the forks; should I have used lock-tite on the bolts? I assume that is why I had to ditch the creeper, find the cheater bar, zip- tie the front brake, and lay on the concrete to break the bolts loose on the links.
1.3G is offline
post #2 of 5 Old 07-01-2007, 03:35 PM
The Suzuki manual says nothing about threadlocker there but I used the blue stuff myself.
post #3 of 5 Old 07-01-2007, 05:46 PM Thread Starter
Thanks - will be keeping an eye on it!
1.3G is offline
post #4 of 5 Old 07-02-2007, 05:58 PM
peeweekiwi's Avatar
Lock-tite 243
Blue.
Also, if you've ever fitted the Givi crash bars, you will find that Suzuki used lock-tite, or an equivalent, to lock the bolts holding the frame together, together.
Getting the originals out is a bastard
DL1K , fettled.
peeweekiwi is offline
post #5 of 5 Old 07-04-2007, 03:48 PM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
A good reason to have an impact wrench! I bought one just to get the countershaft sprocket nut off but it's been useful for most of the lower bolts.
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
