Chain Problem?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 08-25-2013, 08:03 PM Thread Starter
Chain Problem??
Replaced my original chain at 25,000 mi just for grins. It was still in good shape and I never lubed it.
My mechanic replaced it and I've noticed that it has a tight spot or two. I noticed it early on and it now has 7,000 miles on it. I've adjusted it so it has about 1 inch slack on the loose part and about less than 1/2 inch on the tight part.
Did I get stuck with a cheap chain?? Do I need to replace it?? I have been lubing fairly regularly as apposed to the original.
2009 DL650
Stromburger is offline
post #2 of 11 Old 08-25-2013, 08:15 PM
wills wheels's Avatar
Put the old one back on and grin again
2012 DL1000 Adventure
wills wheels is offline
post #3 of 11 Old 08-25-2013, 08:17 PM Thread Starter
Old one is long gone!
2009 DL650
post #4 of 11 Old 08-25-2013, 08:22 PM
bwringer's Avatar
You've adjusted it WAY too tight, for starters. Undo that before you do expensive damage.
A chain with only 7,000 miles should not have loose and tight spots.
Could be a cheap chain. Could be ruined if it was adjusted with less than an inch of slack from the beginning.
bwringer is offline
post #5 of 11 Old 08-25-2013, 08:33 PM
There are plenty of people, including myself, that believe a new chain should run on new sprockets. You didn't mention new sprockets.
(Not trying to start another oil thread.)
Solo is offline
post #6 of 11 Old 08-25-2013, 08:37 PM Thread Starter
I kept it adjusted properly from the start. I'll go back out and loosen it. The front sprocket was changed, not the rear. I'm thinking it's a junk chain.
This shouldn't happen after 5k mi or less should it??
2009 DL650
post #7 of 11 Old 08-25-2013, 08:37 PM
randyo's Avatar
way too tight
beware of damage to the countershaft, countershaft bearing & countershaft seal
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #8 of 11 Old 08-26-2013, 05:06 AM
Chains
New chains have loose and tight spots. Always adjust it on the tightest spot according to the owners manual.
RichardD is offline
post #9 of 11 Old 08-26-2013, 10:19 AM
richw is offline
post #10 of 11 Old 08-26-2013, 08:37 PM Thread Starter
So, would you replace it??
2009 DL650
