Who uses Synthetic oil ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Closed Thread
post #1 of 29 Old 06-27-2007, 11:52 AM Thread Starter
squeegee's Avatar
All right guys I don't want to start and "Oil War" like Bush .... but My DL650K7 is the first new thing I have bought in this millennium! So now I have an excuse to finally commit to Synthetic motor oil. I have heard the rumors of a wet clutch "slipping" when used in (older?) bikes and so I have always stayed away ... I have also heard that once you commit to synthetic dont go back to mineral ... anybody heard the same? I have read The Engine Oil Bible (which anybody that owns anything that uses motor oil should read ... http://www.carbibles.com/engineoil_bible.html) BUT ....
HOW MANY YA'LL USE SYNTHETIC? Thanks in advance ... the Squeegee
squeegee is offline
post #2 of 29 Old 06-27-2007, 12:07 PM
Do synthetic.
Shell Synthetic Rotella from walmart $16-18.OO for 4 quarts.
Hi Flo 138 Oil Filter $5-6.00.
Bonne Chance
N/F
68 360 Bultaco Diablo
69 CB 500-4
71 CB 750-4
83 GoldWing
89 Goldwing (120,000 miles)
93 Springer Softail (106,000 miles)
99 GeezerGlideClassic (108,000 miles)
07 DL 650 (58,000 miles)
09 FJR 1300 (53,000 miles currently)
11 Triumph Tiger 800 (15700 miles currently)
Frenchie is offline
post #3 of 29 Old 06-27-2007, 12:11 PM
cmosentine's Avatar
Molibe Racing 4T.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #4 of 29 Old 06-27-2007, 12:36 PM
Destro's Avatar
I'll second that!
Destro is offline
post #5 of 29 Old 06-27-2007, 12:38 PM
Third it. The 5W-40 stuff is synthetic and the 15W-40 is dino. http://motorcycleinfo.calsci.com/Oils1.html Now I have to decide whether to report this as another $^&%$ oil thread.
post #6 of 29 Old 06-27-2007, 02:18 PM Thread Starter
squeegee's Avatar
So you guys are using Shell Synthetic Rotella, which is just a muti-use oil, not made for motorcycle or 4 stroke engines?
squeegee is offline
post #7 of 29 Old 06-27-2007, 02:28 PM
It's formulated for four stroke diesels. Check the link.
post #8 of 29 Old 06-27-2007, 02:41 PM
I know first hand cause I used to be a Diesel Fitter.
I worked in a panty factory.... I'd hold em up and yell "Diesel Fitter"
Seriously, ......a 4 stroke motor oil that is made for million mile motors, would infer that all sae certifications are complied with.
N/F
69 CB 500-4
71 CB 750-4
83 GoldWing
Frenchie is offline
post #9 of 29 Old 06-27-2007, 02:50 PM
Destro's Avatar
ROTELLA Products
ROTELLA® T Synthetic Fully synthetic heavy-duty engine oil.
Product Description
Shell Rotella® T Synthetic SAE 5W-40 is a fully synthetic heavy-duty diesel and gasoline engine oil developed especially to meet the requirements of North American driving.
The exclusive Shell formulation offers users exceptional performance and protection in combination with enhanced fuel economy potential over conventional 15W-40 motor oils. This synthetic multigrade engine oil meets the service requirements of virtually all four cycle diesel and many gasoline engine manufacturers.
Applications
  • Recommended for new and older diesel- and gasoline-powered vehicles, including personal vehicles and commercial vehicles such as on-road, off-the-road, truck rental, pickups, delivery, utility, and school bus fleets
  • Meets or exceeds the diesel engine requirements of API CI-4 PLUS, Cummins CES 20078, Detroit Diesel, John Deere, Dodge, Ford, GM, International, Mack EO-N Premium Plus 03, Volvo and others; For gasoline engines, it exceeds API SL.
Features/Benefits
  • Formulated for multipurpose use, simplifying inventory needs
  • Outstanding wear protection and bearing corrosion control helps maximize engine life
  • Helps speed cold starts even with low winter temperatures
  • Enhanced oxidation stability and soot control, especially at higher temperatures, aids service life
  • Improved fuel economy – when compared to conventional SAE 15W-40 oils
  • Product is warranted against defect and has performance which meets or exceeds virtually all equipment manufacturer’s engine oil warranty requirements.
Approvals and Recommendations
  • API CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF
  • API SL, SJ, SH
  • Cummins CES 20078, 20076, 20071
  • Detroit Diesel 7SE 270
  • Mack EO-N Premium Plus ’03, EO-N, EO-M Plus
  • Volvo VDS 2
'nuff said
Destro is offline
post #10 of 29 Old 06-27-2007, 03:15 PM
Jester's Avatar
+1 on the Rotella
-Jester-
2006 DL1000 - Red
"The means of defense against foreign danger historically have become the instruments of tyranny at home." -James Madison
Jester is offline
Closed Thread
