drive belt instead of chain - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 08-10-2013, 10:27 PM Thread Starter
Does anyone offer a conversion for the Strom to go from chain to a belt drive system?? Chain adjustments and wear are a pain. I know that chains are relativily inexpensive. Other bikes have belt drive, why not the Strom.
1981 Yamaha 650 Special(first ride)
1986 Yahama Fazer 700 FZX(sold in 99)
2005 DL 650( best ride so far)
dagwood328 is offline
post #2 of 24 Old 08-10-2013, 10:41 PM
My understanding its that gravel eats up belts.
dkayak1 is offline
post #3 of 24 Old 08-10-2013, 10:52 PM
Old Mike's Avatar
Chain Adjustment
In my personal opinion and case I have found that I buy a GOOD X-Ring chain, RK GB525XSO, that the need to adjust & lube are greatly reduced. Last year I put on a new RK GB525XSO chain & sprockets front & rear shortly before making a 4,000 mile trip, highway only, and I only had to make less than a 1/4 to 1/3 turn on each chain adjuster at the 2,000 mile mark & I only lubed it at that point too. I get good sprocket wear. I am not sure if that is the case with others too or not.
Keep The Rubber Side Down!
2006 DL650
2013 WR450F
2004 DRZ435S
1999 YZ400F
Old Mike is offline
post #4 of 24 Old 08-11-2013, 06:38 AM
You actually should be cleaning/lubing the sealing rings
richw is offline
post #5 of 24 Old 08-11-2013, 08:16 AM
VH Motorradtechnik Shop of Germany used to make one for 2004-2006 DL650s but I don't see it on their site any more. It was thousands of dollars and was not an easy conversion. They wanted you to bring the bike to a qualified installer.
post #6 of 24 Old 08-11-2013, 10:55 AM
It might be worthwhile contacting the gentleman in Germany. He might still have the parts in stock ... just lack of demand made him take it off his marketing package.
And if that is the case ... it might be a bit less expensive.
Just a thought.
Banks C[FONT=Comic Sans MS]:crying:[/FONT]
2006 DL650 Current Engine 15,625 Prior engine 67,426 when chain came off and bent valves
2005 Yamaha FJR1300A 68,000 miles and counting
Banks C is offline
post #7 of 24 Old 08-11-2013, 12:45 PM Thread Starter
chain
I clean and lube the chain every 500 miles or right after riding in rain or dirt.
I just must have a poor quality chain. I'm not sure how the previous owner took care of it. I do have a new chain ordered. The sprockets are in good shape, several of the links are seized. I have lubed and cleaned but still stuck.
post #8 of 24 Old 08-11-2013, 04:18 PM
There's these guys-cruisers only now but if you talk nice to them...
Motorcycle Accessories, motorcycle parts, Belt Drives, lowering kits, handlebar risers
And there's the guys who do the Triumph belt systems, not sure of their url...
houseofcharm is offline
post #9 of 24 Old 08-12-2013, 01:00 AM
ozart's Avatar
What affect does running a super tight chain have on the output shaft bearing?
Would that be similar to running a belt?
ozart is offline
post #10 of 24 Old 08-12-2013, 06:37 AM
kitesurfer's Avatar
belts are not as strong as chains. a harley drive belt would not hold up to a wee strom power. Notice the 4" width of belts on custom bikes..
2012 DL650
U.S. NAVY, RETIRED
kitesurfer is offline
