What fuel Octane are you using? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 06-18-2007, 09:13 PM Thread Starter
Super Dave's Avatar
I have a 2006 DL1000 with about 12,000 km. I have noticed a pinging sound durring moderate to hard acceleration from about 4000 rpm. It only pings a few times. I normally use 87 octane but have tried 89 & 91 octane and have noticed the noise is gone.The motor seems to run better as well. When I went back to 87 octane the ping came back.
The manual says to use 91 but there is a section for Canada that says to use 87.
I don't know if they measure octane differently between the U.S and Canada or weather there is something done differently in the ignition module.
Has anyone had any similar experiance?
Super Dave is offline
post #2 of 19 Old 06-18-2007, 09:47 PM Thread Starter
Super Dave's Avatar
Thanks for the info
I'll stick with the 91 (in Canada) since it seems to fix the problem.
It's about 15 cents a litre more which is about $3.00 extra for a full tank. Not a high price to pay for better performance.
post #3 of 19 Old 06-18-2007, 09:58 PM
savvy's Avatar
a mechanic friend recommended the mid range octane over the 87. my bike didn't like to pull from 2000 rpm very much. so i put it in and it seems like a new bike now, pulling comfortably from 2000, and the 3200 rpm "chudder" seems less also.
i have a feeling if everything was tuned properly i wouldn't need the better gas, but i just got it and haven't done any work on it yet.
mike
DL1000 K3
author of future books, "Stuck in Pickering" and "Only Cowards Stay Married"
savvy is offline
post #4 of 19 Old 06-18-2007, 10:05 PM Thread Starter
Super Dave's Avatar
mike
It ran fine on the 89 Octane as well. I have 12k on it and should probably change the plugs but I figured I would wait until the end of the season.
That front plug is pain to get to.
post #5 of 19 Old 06-18-2007, 10:27 PM
FarmerStrom's Avatar
My Vee is corn-fed with 89 octane gasohol. So far, after 1200 miles, it's getting 44 mpg at average speeds of 65 to 75 mph. And no pinging that I've heard.
I did run one tankful of 87 octane non-gasohol (regular swill) and the mileage dropped to 39 mpg. Could have been higher revs or fighting wind as well as this has been the windiest spring in many years in Iowa.
K6 DL1000 - GIVI V46, GIVI V35s and GIVI crash bars, Madstad, Murph's Brace, Pro-Taper ATV Hi bars
1981 GS650L (for sale)
1977 GS550 (first love)
FarmerStrom is offline
post #6 of 19 Old 06-18-2007, 10:29 PM
87 in the US is 91 in Canada. US uses (R+M)/2 whereas Canada uses R only.
Actually that is incorrect. Canada and the US both use the (R+M)/2 value for octane rating. As such the standard gasolines available in Ontario are 87, 89, and either 91 or 94 depending on which brand is available. Minor variations may exist in different regions due to elevations etc, but as I haven't been to BC I haven't had the opportunity to verify that yet.
Incidentally, my 650 runs just fine on regular grade 87 octane fuel.
04 blue wee
sbdep is offline
post #7 of 19 Old 06-18-2007, 10:49 PM
Originally Posted by Super Dave View Post
Thanks for the info
Hey SuperDave, how did you fit a 6 gallon tank on your DL? That must be some sight!
Math = $3.00 / 0.15 = 20 litres = 5.2 gallons
Also, do you run your tank dry before filling up?
Dave1 is offline
post #8 of 19 Old 06-18-2007, 10:53 PM
MAXSTROMBERG's Avatar
I did notice recently that the 1000 was pinging ever so lightly with the 87. I think I will go up to the 89 next tank and see if that cures it a bit.
Jim
06 DL1000 Canyon Red
Givi racks--E21 bags
Motech engine guards
Motech center stand
Fender extender
Givi E360 top case
MAXSTROMBERG is offline
post #9 of 19 Old 06-18-2007, 11:01 PM
I run 87 when it is mild or Winter, but I sometimes run 89 in the Summer heat.
post #10 of 19 Old 06-18-2007, 11:14 PM
Sorry. Thanks. I deleted the erroneous message. I was thinking about a recent Australian post. Too many mostly English speaking countries. I should have realized it when the availability of 87 was mentioned.
