seeking smoother shifting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 38 Old 06-14-2007, 10:05 AM Thread Starter
most japanese-made transmissions, especially suzukis, tend to get smoother-shifting with miles. but that is not proving to be the case with my vee. if anything, it seems to be a little more notchy than it was when new.
so i've been thinking about experimenting with:
1) removing the circlip and regreasing the pivot point
2) going with synthetic engine oil at my 3k service (i'm at 2.7k miles)
3) ???
any ideas? and thanks in advance ...
TouringDude is offline
post #2 of 38 Old 06-14-2007, 10:18 AM
SCraig's Avatar
Check your chain tension. Mine shifts much smoother when the chain tension is right. Something to do with backlash, I guess, but it makes a big difference on mine.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 38 Old 06-14-2007, 10:20 AM Thread Starter
chain tension is cool.
post #4 of 38 Old 06-14-2007, 10:42 AM
TouringDude,
You might want to take a look at https://www.stromtrooper.com/forums/showthread.php?t=8127
I know when I installed my Master Mike Spacers the shifting was greatly improved.
Just a thought.
fl_strom is offline
post #5 of 38 Old 06-14-2007, 10:44 AM
805gregg's Avatar
Changing to synthetic oil will help.
805gregg is offline
post #6 of 38 Old 06-14-2007, 10:53 AM Thread Starter
Originally Posted by fl_strom View Post
TouringDude,
Just a thought.
Thanks ... i've installed the new spacers. i wonder if perhaps they are not seated correctly?
post #7 of 38 Old 06-14-2007, 05:55 PM
darin bell's Avatar
Ditto on the synthetic.
Darin
___________________________
'05 BMW R1200RT
'03 Honda XR400 (Dual Sported)
'71 AJS 370 Stormer
darin bell is offline
post #8 of 38 Old 06-14-2007, 07:16 PM
weight of oil also makes a big difference. For example, 15-50 Mobil 1 shifts better than 15-40 Rotella. But I think the smoothest I have tried is 5-40 Rotella synthetic. As a side note, I noticed my cam chain on my 1st gen SV I had was noiser with the less wieght oil.
What oil and weight are you using?
DaddyO is offline
post #9 of 38 Old 06-14-2007, 07:25 PM Thread Starter
honda 10-40 motorcycle oil. dinosaur juice.
post #10 of 38 Old 06-14-2007, 07:41 PM
MightyShep
Good Lord it's becoming an oil thread! Run for your lives!!!!!!
