over heating after service need help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-10-2007, 01:51 AM Thread Starter
Ok i did a search first but didn't find the answer i was looking for. I had mv v-strom 1000 serviced at the shop they failed to fill the cooling fluid and it heated to 4 bars on the way home. They picked up the bike and said it just needed burped got it back and it still over heats,took it back they changed the thermostat road it home it hit 4 bars when i pulled in my parkinglot only 6 to 7 miles. It's an 03 with 40k miles what could it be now i'am takeing it back monday already called them but it was to late to take back today. any advice
badcarma is offline
post #2 of 7 Old 06-10-2007, 08:01 AM
Crazy Old Guy
fastwally's Avatar
Is the fan running when at 4 bars?
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #3 of 7 Old 06-10-2007, 08:10 AM
jacob's Avatar
Did the service work involve anything in the cooling system?
02-blue DL1000/94k
jacob is offline
post #4 of 7 Old 06-10-2007, 05:34 PM
What services were performed? Did it have this problem prior to the service work?
Mountaintime05 is offline
post #5 of 7 Old 06-10-2007, 05:52 PM
MightyShep
Check to see if the fan lead is connected. Left side of radiator.
post #6 of 7 Old 06-10-2007, 10:22 PM Thread Starter
the shop changed the oil ,filter and changed the cooling fluid but failed to fill it.It got hot going home when it cooled i checked and the radiator was empty and the fan does work.They picked the bike up at my house approx. 6 to 7 miles from the shop filled the radiator and said the tec.just failed to burp it,it over heated again on the way home so i took it back and they changed the thermostat .They said it could have warped it.and it over heated on the way home a third time.I fear it did damage to the top end but i'am not smelling antifreeze and they said the oil was ok.The bike sounds ok and i was not haveing any over heating problems before only 2 bars all the time i rode it.
badcarma is offline
post #7 of 7 Old 06-11-2007, 08:48 AM
Simple fix - have them fix the damage they have caused. Also tell them this is your primary vehicle and since because of their negligence, they need to provide you with something for transportation - of similar size and capabilities - until they return your vehicle completely repaired.
fl_strom is offline
