Gravel road tire pressure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-05-2007, 01:10 PM Thread Starter
What pressure are you guys riding with for gravel?
(Stock Wee with stock TWs)
TintinStrom is offline
post #2 of 8 Old 06-05-2007, 02:01 PM
zed88's Avatar
Send a message via AIM to zed88
20psi felt great!
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #3 of 8 Old 06-05-2007, 02:33 PM
Dwayne's Avatar
Dumb question... let's say you ride out an hour or two on the slab to go explore some dirt. You get to the dirt, air down to 20 psi, and run around. You're ready to go back home... so do you carry a pump to get your tires back up to pressure so you don't run the heck out of them on the way back?
Dwayne is offline
post #4 of 8 Old 06-05-2007, 02:44 PM
Depending on how rough the road is. I run about 15/18 if it's sandy/gravel/ dirt.
Slime makes a great little set up for roadside repair. It has slime, compressor/ all the wiring to wire it into your bike. I wired mine in so I don't have to remove the seat. Plug it in, reset your preloads and by the time your done, pressures are back up. It took me 3 minutes to be road ready last time.
flyinggreek84 is offline
post #5 of 8 Old 06-05-2007, 02:50 PM
Colin's Avatar
I have a small Airman compressor. It stores behind the tool kit like it was made to go there. I also put in a 12v outlet under the seat.
Colin is offline
post #6 of 8 Old 06-05-2007, 02:52 PM
I use a 12V compressor from my MotoPumps.com tire repair kit. It hooks to the Battery Tender lead I have ziptied to a frame rail (easy access).
garry is offline
post #7 of 8 Old 06-05-2007, 04:21 PM
randyo's Avatar
I ride pavement to gravel to pavement all the time without skipping a beat or changing pace
36f/41r pressure all the time
with soft tires you are likely to ding your rims on rough stuff
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #8 of 8 Old 06-05-2007, 05:24 PM
RandyO is primarily right
I went on a day of some rough stuff, gravel 140 miles and 60 miles of pavement on Sunday May 27. I reduced the pressure in the front down to about 26 and the rear down to 30.
Worked great on the rougher stuff and less squirmy on the gravel. I did bend my rim on a cattle grate. Front tire compressed down enough to hit both sides.
I think I would still reduce the pressure some for a day like that, but I would not go much below what I did.
JayR is offline
