Tire Rub ... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 06-03-2007, 07:36 PM Thread Starter
Send a message via Skype™ to defusingdanger
Question Tire Rub ...
Under heavy braking, my fonrt tire is rubbing on somthing; as it is hard to see down there (without going over the handlebars), does anyone have a sugestion of what this might be? I have a fenda extenda, if that helps.
Thanks,
Christian J.S.
defusingdanger is offline
post #2 of 11 Old 06-03-2007, 08:26 PM
Have you checked that the brake stuff (lines, calipers, etc) are not loose? Also check to see if your tire has anything stuck in it. I have the fenda extender and cant see how that could cause a problem unless that is loose. But check the fender. I had to losen my fender to put it on. Putting back the brake line bolts was tricky.
ImOk is offline
post #3 of 11 Old 06-03-2007, 08:33 PM
MAXSTROMBERG's Avatar
Also check the tire pressure. Too little air will have your tire to a point where the squeal you hear will sound like something rubbing.
Jim
MAXSTROMBERG is offline
post #4 of 11 Old 06-04-2007, 08:04 PM Thread Starter
Unhappy None of the above
Unfortunately, it's not either. I have 36 PSI, and I can find nothing that is lose... Other ideas?
Cheers,
Christian J.S.
DL1000 '06 *Green*
"All animals are equal, but some animals are more equal than others."
(such as the '1000)
post #5 of 11 Old 06-04-2007, 09:47 PM
Laava's Avatar
My new DL did the same thing for a while, under moderate to heavy braking it sounded like the front tire was half flat. Went away after a while. My 1st new DL didn't do it! Go figure? Disc pads settling in?
L4 DL1000 Black Strom No3
Laava is offline
post #6 of 11 Old 06-04-2007, 10:06 PM
I rock at logic
LucasD's Avatar
My Wee feels the same way. Very strange feeling, but I don't think it's the tire rubbing on anything... I'm not sure what it is.
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #7 of 11 Old 06-04-2007, 10:10 PM
Under hard braking the front brakes will sometimes make the front fender rattle or buzz, also the stock front tire is noisey under hard braking, mine would howl like a off road truck tire under hard braking.
Mortaine is offline
post #8 of 11 Old 06-05-2007, 09:03 PM
Mike D.'s Avatar
Smile Harmonic noise
I have an 07 Wee and have noticed some harmonic noise several times while braking. When this occurs it does feel as though something is rubbing due to the high frequency vibrations, a slight groaning sound is also heard. I'm not sure if this is what you are experiencing, it's just a thought. Be safe and have fun Mike D.
Mike D. is offline
post #9 of 11 Old 06-05-2007, 10:31 PM Thread Starter
Red face Maybe so
I think this vibration thing may be it. So hopefully on Friday--when I get a shinny new fork brace--all that buzzing will be no more.
Cheers,
Christian J.S.
DL1000 '06 *Green*
(such as the '1000)
post #10 of 11 Old 06-07-2007, 12:32 PM
Then jack up the front end and spin the tire for anything that looks out of place, even minimally. Tire to fender clearance would probably stay the same in this case, but I would check all of it for tightness/straightness. IF you have a fork brace, loosen your pinch bolts and axle, check to make sure the brace is on straight, and re-tighten everything.
Jim
06 DL1000 Canyon Red
Givi racks--E21 bags
Motech engine guards
Motech center stand
Fender extender
Givi E360 top case
