Re-installing the rubber pad where at tailcase goes - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-25-2007, 06:16 PM Thread Starter
Re-installing the rubber pad where the tailcase goes
Any special tricks to it or is it just simply a bit of dish soap and some long needle nose pliers? Bought my bike today and the previous owner didn't put it back on after he took off his tailcase.
jerrmy is offline
post #2 of 6 Old 05-25-2007, 07:34 PM
2wheeldeb's Avatar
Just did this last week and an exacto knife to trim the inner edges a bit soapy water and yes needle nose pliers all work well.
deb
2wheeldeb is offline
post #3 of 6 Old 05-25-2007, 07:43 PM
Didn't think about the water...
I used the pliers only
emsdaddy is offline
post #4 of 6 Old 05-26-2007, 02:02 PM
Wee_Willie's Avatar
Silicone spray persuades the "Nubs". I found that needle nose, alone, would pull the ends off. Used a small tip straight blade screwdriver to push the nub while my Sig Other pulled slighty with the needle nose. My .02 cents. They are a ROYAL Pain In The A$$!
Willie
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #5 of 6 Old 05-27-2007, 07:53 PM
I'm still trying to figure out why people take them off. My top case mounted up and has stayed tight.
icanfixthat is offline
post #6 of 6 Old 05-27-2007, 08:42 PM
Tollster's Avatar
Willie
+1, You beat me to it willy
Tollster is offline
