Lower speed Wobble, around 50 km/h or 30 mph - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-21-2007, 09:29 PM Thread Starter
V-Tom's Avatar
Hi All,
I had vaguely noticed this in the past but not the I have my NEP Throttle Lock installed I can do all kinds of dumb things.. like ride with no hands.
I noticed (and vaguely recall hearing previously) of lower speed wobbles when lightly or not holding the handlebars.
Is this the kind of thing that a Fork Braces can cure? It isn't any kind of a big deal, and can be instantly stopped by grabbing the bars, but I was thinking of getting a Brace anyway.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #2 of 12 Old 05-21-2007, 09:39 PM
The Shepherd's Avatar
Ride faster !!!
Otherwise I have nothing worthy of posting.
See you out there,
Me
Ian
'07 KLX250S - Road
'00 CBR600F4 - Track
"The World is a book, and those who do not travel read only a page" - St. Augustine
The Shepherd is offline
post #3 of 12 Old 05-21-2007, 10:00 PM
SCraig's Avatar
I never noticed a slow-speed wobble, but I do have a fork brace on my bike. Where I noticed the greatest improvement before and after the brace was in conditions with a side wind. Passing trucks on the slab used to be real ugly. With the fork brace I can ride right beside them with no problems. I know that doesn't answer your question, but there is a noticeable reduction in wobble before and after installing the brace.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 12 Old 05-21-2007, 10:34 PM
I'll bet you have a Metzler Tourance front tire?
ExBeemerBill is offline
post #5 of 12 Old 05-22-2007, 01:09 AM Thread Starter
V-Tom's Avatar
The tire is stock. I have lowered the front fork about half an inch, but I think I noticed it when the bike was new as well.
It isn't a wobble that wants to keep getting worse.. a light touch stops it. It is just noticeable at that speed range.
..Tom
V-Tom is online now
post #6 of 12 Old 05-22-2007, 01:10 AM Thread Starter
V-Tom's Avatar
You might be on to something...
It doesn't wobble at higher speeds up to 170 kph, only the gentle one at the low speed but only with no hands on the handlebar.
..Tom
Originally Posted by The Shepherd View Post
Ride faster !!!
See you out there,
Me
V-Tom is online now
post #7 of 12 Old 05-22-2007, 01:19 AM
I had the same problem. It is the front tire. The Bridgestone gets a few miles on it and gets that funky wear pattern. It gets worse as time goes on. One thing to do is run slightly less air pressure than recomended. I tried the Metzler and quickly changed it back to the BS. I run the Metzler on the rear and the BS on the front.
I haven't added a fork brace yet, but it surely won't hurt.
flyinggreek84 is offline
post #8 of 12 Old 05-22-2007, 07:28 AM
Most motorcycles I have ever ridden will have a wobble with no hands on the handlbars at some speed.
Much of it is due to the steering head bearings not being adjusted properly - usually too loose. Those bearings will loosen as you ride and need to be periodically adjusted.
MightyShep has an online Service Manual available for your use. Follow this link over to the procedure for checking this tension.
Hope this helps.
fl_strom is offline
post #9 of 12 Old 05-22-2007, 11:17 AM
Night_Wolf's Avatar
I got it on my 05 Wee with the ME880 front and it's a little better with the Avon Venom X
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #10 of 12 Old 05-22-2007, 11:30 AM
MightyShep
I had a wobble like that with my stock tire, when I switched to a Bridgestone BT020 it stopped. Now I have Metzler Tourances and no wobble either. Maybe the tread pattern or the tire itself.
