Total rookie question - risers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 05-21-2007, 01:40 AM Thread Starter
Ok, so I just got my v-strom friday night and love it. The seating position is far superior to my ninja 500 but the one thing that I notice is how quickly my hands fall asleep when riding. I'm talking about 10 minutes before numb!
Can this be solved by adding some handlebar risers?
Here are the specs I am about 6'1" and my reach is about 35". When riding my arms are not quite fully extended. If I were to get some risers to move up and towards me would that help?
So I guess the general question is what are risers used for specifically other than "comfort"? In other words, what should moving up solve, What does moving in solve, what does doing both solve...
Any other suggestions for how to not go numb so quickly would be greatly appreciated as well.
thanks
sactownridder is offline
post #2 of 15 Old 05-21-2007, 03:09 AM
Just got my DL1000k today! I noticed a bit of numbness as well but my ride was about 250 miles and it mostly started near the end when it got really windy and I had to hold on a bit more to correct as it kept blowing me sideways.
I usually ride with a fairly loose grip and hug the tank with my knees as having a death grip usually translates into too much unintentional rider feedback on the bars which causes oscillations and works against the suspension somewhat (read Twist of the Wrist by Keith Code if you haven't already, its a great book!)
Try to loosen your grip a bit as that might help a little. I've heard the "Bar Snake" also works to take out some vibes.
Not sure if the risers will do much but haven't tried that myself as the stock bars seem about the right height to me.
Good luck and keep us posted with whatever you try!
Gr8fuljack is offline
post #3 of 15 Old 05-21-2007, 04:20 AM
sactownridder,
The "fit" of a motorcycle is the most important thing to consider. Let's be totally honest here, if it does not fit you comfortably, you are not going to be happy riding it and it will cause irritation, which will detract from you alertness.
Risers are something I have on my Strom. I also tilted the stock handlebars back a few degrees to relieve a bit of the pressure on the wrists when riding. My footpegs are a bit lower thanks to MotorcycleLarry's footpeg lowering adaptors and a set of IMS footpegs.
My bike fits me very well now and is quite comfortable.
Try this: get your bike set up, then head up to Redding and have a steak at "Jack's Steakhouse". I'll bet it makes for a great ride!
fl_strom is offline
post #4 of 15 Old 05-21-2007, 09:39 AM
A1A
Smile
I agree with what others have suggested for you. You could put on Grip Puppies for the hand grips as well. I would suggest you get as much riding time as possible. After you make the suggested changes you will probably find you don't have a problem after all.
HTH's
Richard #3125
Blue 05 DL650
Yellow 04 SV650N Scantily Clad
A1A is offline
post #5 of 15 Old 05-21-2007, 10:26 AM
my hands go numb too. not sure if it's ergonomics or v-twin vibration. i plan to experiement with two solutions:
1) crampbusters ... a plastic slip-on device for the twistgrip that allows you to control the throttle while gripping very loosely. i find i can delay the onset of numbness if i focus on gripping the throttle loosely ... and the crampbuster helps you do this. http://www.cartestsoftware.com/fz1/crampbuster.html
2) hunter flatbars ... a more extreme solution that replaces the final 5 or 6 inches of your handlebar with an aluminum vibration damper. people who have tried it swear by it. http://www.hunterflatbars.com/
TouringDude is offline
post #6 of 15 Old 05-21-2007, 11:37 AM
Colin's Avatar
I was also having some numbness issues although it took longer than 10 min for me. It felt like I was always just between leaning into the bars and sitting up. The first thing I did was adjust the bars back a bit since that was the easiest thing to do and it helped a bit.
I got a deal on some genmar up and back risers and after I installed them the difference was like night and day!! No more cramping or numbness at all.
I also got a crampbuster and grip puppies from CalSport Touring and now I'm a very happy puppie:-D
Colin is offline
post #7 of 15 Old 05-21-2007, 11:41 AM
mtlee's Avatar
Stance vs. vibration
Sactown -
First thing to determine is what's the cause of your numbness - vibration, hand/wrist position, or weight on your hands. If you are not feeling a lot of vibration right off the bat, I would guess that's not the issue.
Look at your hand position when you're seated in riding position - are your wrists bent back? That's a classic position for causing nerve issues like numbness and repetitive stress. If that's happening, try having someone hold the bike up for you in the garage/driveway and play around with how upright you sit until you can hold your wrists in a more neutral position. If you can't achieve that with the current or rotated handlebar position, then risers or a new bar may be in your future.
If your wrists are in neutral position, then it may be the amount of weight you're placing on your hands. Again, sitting more upright may help here - do the same driveway experiment.
Good luck!
Mike
mtlee is offline
post #8 of 15 Old 05-21-2007, 02:15 PM
aps45819's Avatar
I switched to gel grips, fixed the problem. You might also try heavier bar end weights.
'06 DL1000 new on 1/13/06
The difference between driving a car and climbing onto a motorcycle is the difference between watching TV and actually living your life.
aps45819 is offline
post #9 of 15 Old 05-21-2007, 03:04 PM
nvr2old's Avatar
I'm also 6'1" with a 34" reach. I bought the Wee used with the 1" up 1" back risers already on (also moved up from a EX 500). My rides have been as long as 500 miles in a day and had no discomfort at all. Don't know how it would be without them but, its so comfortable that I have no reason to try changing back.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #10 of 15 Old 05-21-2007, 03:52 PM
Nighthawk22's Avatar
Up and backs worked great for my wrist pain and Grip Puppies helped with the hand cramps. The grips are too thin, the Grip puppies allowed me to relax my grip some. Bout time to replace them, though. They're about 9 months old and loosing some of their cush.
Member: American Legion Riders
'09 DL1000
'02 Goldwing 1800 (Toni the Tiger)
'06 6fifty strom(a distant memory)
"Ask permission only if "no" is an acceptable answer."
Nighthawk22 is offline
