t r e's do they work - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-19-2007, 05:39 PM Thread Starter
hi been looking on ebay and there are some tre's for sale has anyone used them and do they help with low speed town riding my bike coughs back fires and sometimes stalls around town ?
mr mellie mel is offline
post #2 of 3 Old 05-19-2007, 10:00 PM
Ivan's thing will do nothing in the 1st 4 gears and nothing in the upper gears below 7600 rpm or so. This is where the stock restrictor kicks in by manipulating the secondary's to restrict airflow.
By removing the secondary's altogether there is no need for a TRE and you get better airflow throughout the RPM range.
"coughs back fires and sometimes stalls around town"
Do a TBS synchronization, however as you start to put the miles on your bike the throttle body's will ware at different rates making it harder to sync them throughout the rpm range. Fear not there is a fix.
http://vstrom.info/faq/index.php?sid...=67&artlang=en
My advise to do all the cheap and free fixs first then go from there.
1) The NGK iridium spark no. NGK CR8EIX.
2) http://vstrom.info/faq/index.php?act...=29&artlang=en
3) http://vstrom.info/faq/index.php?act...=28&artlang=en
4) Throttle Body/IAPS vacuum balancer
5) Make sure your airbox is seated properly around the throttles bodies
IslandStrom is offline
post #3 of 3 Old 05-20-2007, 03:42 AM Thread Starter
Smile tre's
thanks for the info , i will start a to do list and try to get it sorted . going to spend a week touring round france at the end of june so hopefully can get it ready by then . cheers:-D
