Fiddling with your camera - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-14-2007, 01:58 PM Thread Starter
WARainman's Avatar
Went on a ride the other day and took a few pictures. I found it quite awkward fiddling with my camera while riding. I would like to mount the camera on the bike with a mount that allows the camera to easily be pointed in different directions.
What are you doing to take pictures while riding? Can I see pics of your mounts and/or any tips or suggestions.
TIA
WARainman is offline
post #2 of 12 Old 05-14-2007, 03:29 PM
Jblk9695's Avatar
Go to this thread to see a mount I made for stills and video. Works great for stills and not to bad for video, but I bit the bullet(pun intended) and bought a bullet cam. Might still use the mount for the bullet cam cause it won't bounce around as much due to the lighter weight jof the camera.
https://www.stromtrooper.com/forums/s...ead.php?t=9646
Jerry
Second childhood, heck, I'm still in the first. 72 going on 25
Added an 09 Yamaha FZ6 for my birthday
Sold the FZ6 and got a Triumph Tiger 800
Now have a Triumph Bonneville and an 09 Wee
Retired and lovin it
1945 Wife
Jblk9695 is offline
post #3 of 12 Old 05-14-2007, 05:03 PM
Nighthawk22's Avatar
It's too bad someone doesn't make a left handed camera or a bracket that makes it compatible with the left hand. Could make one if digital cameras had a cable release.
I took a keychain real(clips to your belt and lets you pull your keys out to use, then reals them back in), connected the real to the inside of my tankbag and connected the other to the camera. I grab the camera with my left hand so my index finger is over the button, pull it out, take the picture, then the real guides the camera back to the bag and holds it there without me having to look. It's not the best, still working on aiming with this awkward handhold, but it allows me to protect the camera from weather and bugs, plus I can't loose it if I drop it.
I would go with a bullet cam is it took decent stills, but I haven't seen that yet.
Member: American Legion Riders
'09 DL1000
'02 Goldwing 1800 (Toni the Tiger)
'06 6fifty strom(a distant memory)
"Ask permission only if "no" is an acceptable answer."
Nighthawk22 is offline
post #4 of 12 Old 05-14-2007, 05:41 PM
ratspike's Avatar
That's brilliant Nachodaddy. I've been trying to figure out a way to tether my little digicam. I never would have thought of a retractable keychain.
A small ballhead on a long arm RAM mount would probably do the trick as long as you didn't need to adjust camera position on the move. I have a bunch of these and have used them for mounting my digicam to shoot video.
If you're using an SLR or digicam that has a remote release you can really go overboard. A Bogen pistol grip head would let you adjust the camera while riding, and I bet with a little creativity you could ziptie the remote release to the grip so it was point and shoot. :mrgreen:
Be seeing you...
Bob
ratspike is offline
post #5 of 12 Old 05-14-2007, 08:22 PM
I have a digital SLR-shaped camera(LXI-Panasonic), but it doesn't have a cable release on the button like my old SLR. If it did, I could make a trigger grip that would be ideal. Unless there is an electronic way of having a remote trigger, I'm stuck with what I have.
'09 DL1000
post #6 of 12 Old 05-14-2007, 09:13 PM
ratspike's Avatar
Panasonic does make electronic remote releases for several of their cameras. I'm not actually sure if any of the digital SLRs on the market use mechanical releases. When you're already spending 3 or 4 grand what's another 70 bucks right? :mrgreen:
Be seeing you...
Bob
ratspike is offline
post #7 of 12 Old 05-14-2007, 09:19 PM
K1W1's Avatar
You could always mount the camera upside down and trigger the shutter release with your left thumb under the camera.
K1W1 is offline
post #8 of 12 Old 05-14-2007, 10:14 PM
Jblk9695's Avatar
You don't need to spend that much, just look around and find a used Minolta 5D, it uses a wired remote. Sony bought Minotla's digicam part of the business and came out with the Alpha 100 which is their version of the 5D. Not sure if they kept the wired remote or not. Nikon uses a wireless remote on the D70, not sure about Canon, Pentax or Olympus.
Jerry
1945 Wife
Jblk9695 is offline
post #9 of 12 Old 05-14-2007, 11:42 PM
ratspike's Avatar
Personally I think getting rid of a threaded shutter button in favor of a fancy electronic release is annoying. I'm not sure any of Canon's EOS film bodies used a mechanical release and the digital bodies sure don't. At least the remote release I bought for my 10D works with all the bodies I've purchased since. I'm not sure Canon ever made a wireless release. IIRC the original Digital Rebel had an IR shutter release widget but it didn't work with any of the professional bodies. I guess it's assumed you're using Pocket Wizards and don't need any help from Canon.
Be seeing you...
Bob
ratspike is offline
post #10 of 12 Old 05-15-2007, 12:15 AM
Jblk9695's Avatar
+1 on the cable release. I used to have a Minolta X700 that I mounted on the crash bars of a Gold Wing and just wire tied the cable release right by the grip, worked great.
Jerry
1945 Wife
Jblk9695 is offline
