hid lights and integrated tail light - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 05-13-2007, 11:54 PM Thread Starter
has anyone here put on a hid kit or changed the bulbs in the front to turn them more white? and do they make a integrated tail light for the v strom? thanks for any help:mrgreen:
nick_villan is offline
post #2 of 21 Old 05-14-2007, 12:42 AM
Compared To What?'s Avatar
I replaced my OE bulbs with Phillips vision plus when I first purchased my 6Fiddy. Never felt the need for any additional lighting in front. Also dumped the OE 2 candlepower blinkers and replaced them with 21w halogens.
Compared To What? is offline
post #3 of 21 Old 05-14-2007, 01:05 AM
BDragon's Avatar
I put HID's in place of the stock bulbs. Took it out soon after. 1 Ballast burned out or something. Damn Chinese imports! I had alot of cars flash me, then I high beamed them and they weren't too happy about that. The light position is so high. It hits cages right in their eyes. Suckers.
Givi Windscreen, Madstads, E21 & E41 Panniers, E52 Top Case, Scorpion Stainless Exhaust, Famsa Tank Bag & Panniers, Symtec heated Grips w/ Grip Puppies, Pat Walsh Engine Guard / Skid Plate, OEM Handgaurds, OEM Center Stand, SWMotech Mirror Wideners, Metzler Tourance, 4" ABS Tube, AutoCom Pro 7, GIPro, Sargent Seat, BSS Fuse Block & Relay, Garmin Zumo 550, Stebel Air Horn, Aux Powerlets, Alaskan Leather, PIAA xtreme white, Superbrace, ToolTube, Kaoko Throttle Control, Highway Pegs, Risers (1" up 1" back) Sonic Springs, 1" raising links, PIAA 510 ATP, Touratech LED Tail Light, Touratech Zumo mount.
BDragon is offline
post #4 of 21 Old 05-14-2007, 03:47 AM
C T W, where did you find 21 watt halogens ?? And all the usual questions.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 21 Old 05-14-2007, 08:27 AM
MZBuckeye's Avatar
The reflector design of the Strom's headlights is absolutely horrible for true HID's. You'll blind the ever living shit out of everyone coming the other way. If you really want to add HID's, the best way to do it would be to retrofit in a set of HID projectors into the stock headlights. This is what I did on my Mazda6, and the results are fantastic.
Any and all info you might need on HIDs can be found on www.hidplanet.com
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #6 of 21 Old 05-14-2007, 10:55 AM Thread Starter
:shock:, dude i dont want to blind anyone..lol. Maibe ill just change the bulb for a white one, does anyone here know how i `can find that out?
post #7 of 21 Old 05-14-2007, 12:25 PM
Home Depot. . . .
Had to manufacture my own connections after stripping all the OE stuff out of the housings. . .
Compared to the OE Non-reflectors these babies have some reflective area. I thought there might be "issues" with vibration but now with more than 25K on the "mod" and ZERO failures I figure it's a non-issue.
post #8 of 21 Old 05-14-2007, 03:23 PM
Amp Draw?
what was/is the wattage of the OEM bulb? i know that the turn signal is an intermittant circuit, but i'm worried about torching the flasher module... as well as frying the wires...
any thoughts? any one?
Jeff
Blue 2005 DL-650 (2005 - present)
83 Honda Shadow 750 (sold for parts)
70 Bridgestone 100 (oil injector) ("Blown-up, Sir")
Jeffjan2001 is offline
post #9 of 21 Old 05-14-2007, 09:59 PM
Shortly after getting the bike, while riding with friends - they asked "are you using your turnsignals? We don't see anything." They are pathetic - invisible in daytime.
I adapted and installed halogens - you can't miss them now. No heat problems, no wiring problems, no problems.
Search this site for installation tips and techniques (maybe 2-3 years ago) if you like.
2004 dl650-the urban warrior.
2007 R1200RT - the highway beast
tinman is offline
post #10 of 21 Old 05-14-2007, 11:35 PM
As "Compared To What" said, he has 25k on the HID's and hasn't had a problem. The V-Strom has about 100 watts extra to play with (wee strom a little less), so 21 watts shouldn't be a problem. The stock bulb is 10 watts. I've had HID running lights on my DL1000 for over a year (55watts each), and have not experienced any problems yet. I try not to run the lights for extended periods because I know that I'm pushing the max, but I'm paranoid about deers after hitting one in California. I'd rather see a deer than worry about a burned wire.
motoxusa is offline
